586,103 active members*
3,866 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Need bar stock with a 1mm hole going through the length of it?
    May 2007
    320
    What is this type of bar stock called that has a hole running through the center of it along it's length? I need about 1" OD 316ss rod with about a 1mm hole running through the length of it..
    is it expensive?
    Mar 2006
    2712
    I don't know of any hollow bar or mechanical tubing or other type that has a 1mm hole thru its length. Maybe somebody in the hypodermic needle business? How long is the workpiece/hole? I've seen some relatively deep holes sunk with hollow tube EDM electrodes. .010"/.25mm dia. self flushing tubes resulted in .013" dia. holes about 1" deep. Hope that helps.
    Dick Z
    DZASTR
    May 2007
    320
    I need to go about 6 inches long, .145" OD of the workpiece and a hole that is 1mm diameter going through the center of the workpiece end to end..
    Feb 2008
    24
    cannulated stock, forecreau usa has it (I may have spelled that wrong)
  1. X2 R8 Drawbar length???
    By maxboostbusa in forum Benchtop Machines
    Last Post: 10-05-2007, 04:09 AM
  2. cut to length
    By chathorne in forum Uncategorised MetalWorking Machines
    Last Post: 04-25-2007, 04:47 PM
  3. Max length of linear rod?
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 03-06-2005, 03:47 AM
  4. head stock and tail stock chucks
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 10-20-2004, 03:16 AM
  5. Linear rod+max length?
    By smythe in forum DIY CNC Router Table Machines
    Last Post: 08-31-2004, 02:19 AM
