Hello,
I'm new to CNC so please bear with me. I am using an older Supermax mill with a Fanuc OM control on it. It does not have a toolchanger so I have to change then manually. The problem I'm having is that when a program calls for a tool number the program pauses. The green cycle start button stays lit, but nothing happens? If I press reset it will continue on, but, it will skip the line of code under it. Also It is not picking up the tool size in the control.
I would like to be able to use the tool # to be able to change the size of the tool so I can adjust the sizes of my tools if needed.
Any suggestions?
Thanks, Wes
