I have seen many posts where people are having problems with programs.
The machine does this and that when it shouldn't.
Why not make it a habit to post a sample of the program.
It makes it so much easier to see what's wrong and help.
Stefan Vendin
I second this suggestion and add; copy and paste the actual program don't just retype a segment. Typos can occur during retyping which just confuses the issue.
It also makes sense to specify the machine the control and also put a few punctuation marks in sentences. Some of the posts are a joke we ought to start a new forum with all the worst examples posted. You know the kind " Need help how to mill a circle ? " .
Stu
Use of the code tags helps a lot, sets off the program and preserves the formatting.
Just push this button and put your text between the start and end tags which are inside the two sets of square brackets.
Code:N1M1(3/8 END MILL) T#101M6 M1 G0G90G#103X0.000Y0.000 S3565M3 G43Z1.000H#101M8 (FEED RATE) #9=21.39 () G65P1001Z-0.750R0.100D#101A#100F#9 G65P1002Z-0.625R0.100D#101A#100F#9 G0Z1.000M9 G91G28Z0M5
Unfortunately, most of "them" won't actually read this thread to take the advice.....:argue:
It's just a part..... cutter still goes round and round....
.... Not very optimistic. Guess my glass was half empty today...
:cheers::cheers:
You're probably right.Most people won't read this thread.
Maybe a sticky would be a good idea?!
My glass is full so fill up. Cheers! :cheers:
Stefan Vendin
Here is a little tool that will help in trouble shooting G and M code, only draw back it does not recognize macros.
Discriminator CNC Editor It is $10 and works well and is a good tool for teaching G and M code along with manual editing and trouble shooting.
You are able to step through each line of code and visually see the output.
My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
Code:Put your code between the tags.
Edit:
Regular text in a reply the "extra" blank spaces get removed.
* I put 9 spaces before the * char.
Also a mono spaced font is used inside the tags so stuff lines up vertically.Code:* I put 9 spaces before the * char. Inside the code tags the spaces are not removed.
Yes. Let's all scream until the site admin makes it so. As a frequent code seeker some of the existing threads are painfull to read. Next question, do people read stickies?
edit/ the petition is here http://www.cnczone.com/forums/showth...196#post404196Code:pasted in from a text editor *nine spaces before the * let's try again *four spaces before the * end of paste test
Anyone who says "It only goes together one way" has no imagination.
