586,104 active members*
3,316 visitors online*
Results 1 to 7 of 7
    Jan 2004
    258
    System variables
    I have looked at my book for any and all listed system variables. From some of the macro's that I have built "all" funtions should have a system variable assinged to them? I wrote a thread a week or two about "G51.1". I now know how it need to be exeacuted and it is a PIA and will require alot moe code in my programs so I will not be using it. I talked to the guy a fanuc and he suggested looking into the ladder for "M" code assingement. I had a chance to work on the machine in question that I am referring to. I the "settings" page is "mirror image x, y & z" switches. What I am wondering is if there is a system variable to toggle these on and off with a macro?
    TIA
    Cncwhiz
    Nov 2005
    219
    whats your email address and I will send you the info I think you want.
    Jan 2004
    258
    theemudracer,
    Check you pm.
    Jan 2004
    258
    I emailed Mike Lynch at cncci.com. He gave me some hints. System variable "3007" is mirror image. I don't know if it is for "X" etc. I will test it and find out. This will allow me to toggle mirror image on and off without the limitations of "G51.1". Of course in a programmers world there is always somthing else. I have a macro for tool changing. Now they want a "M01" so that when it tool changes, when the op stop button is on, after the macro is exacuted it will stop?
    2932
    Here's what I found on Mirror Image #3007
    Jan 2004
    258
    Props to themudracer, he sent me the "complete" macro b programming manual. It has #$it loads of info. Dcouper; this is the parameter that I need to "try" to work with. I believe that the manual talks about using a parameter in a macro.
    Feb 2006
    1792
    Quote Originally Posted by cncwhiz View Post
    Props to themudracer, he sent me the "complete" macro b programming manual. It has # loads of info. Dcouper; this is the parameter that I need to "try" to work with. I believe that the manual talks about using a parameter in a macro.
    Can the same favor be extended to me by themudraser. I also would like to have the macro B manual. I can receive up to 10 MB files on [email protected]
    Thanks in advance !!!
  1. need help with system variables list for mazatrol m/t pro control
    By uperez in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-25-2007, 04:21 PM
  2. System variables in a O-MD
    By AZDEN in forum Fanuc
    Last Post: 10-23-2007, 04:50 PM
  3. System variables
    By jorgehrr in forum G-Code Programing
    Last Post: 02-19-2007, 02:26 AM
  4. Need detailed information for system variables on Fanuc0m control?
    By Alf012 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-03-2005, 07:52 PM
  5. Mori Seiki MF-T6 System Variables
    By EvilScooby in forum Uncategorised CAM Discussion
    Last Post: 06-13-2003, 01:32 AM
