586,069 active members*
3,608 visitors online*
    Jan 2008
    Smile Ball Screws or Belts
    Hi All
    Just starting to think about building my homemade CNC Router, got a few different plans and trying to come up with a design that suits me. What I know for sure is it will be a flying gantry build and it will have a cutting area of about 800mm x 600mm and may cut depths up to 60 - 70mm in pine and mahogonny, possibly a bit larger. So the question is how to move the different axis, I know nearly 80% use a ballscrews, but has anyone used steppers and belts to completly drive there system. What are the advantages and disadvantages of both, what is the best for acuracy, I know you can get precision ballscrews but for the size of the machine, these would leave me broke :-)
    Cheers
    Dougie
    Aug 2006
    102
    Quote Originally Posted by 1druid1 View Post
    Most of the DIY machines use ACME screws which are significantly cheaper than ball screws and ball nuts. All the ACME screws for a 2x4 machine would be less than $100 USD.
    Jan 2008
    Thanks for the reply, for a length of 39" what diameter screw would be best suited, how many starts and turns per inch?
    Cheers
    Dougie
    Jul 2007
    189
    I got all my screws, bearing blocks and a motor mount from these guys.
    They are cheap and will cut the screws to any length you need.
    They cut a 1/4" motor coupler end and two areas that ride in the bearing blocks that they sell.
    http://www.precisiontechmachining.com/
    Aug 2006
    102
    1/2" should be more than plenty. The number of starts and TPI is up to you but common sizes are 10TPI single start and 8TPI 2 start.
  1. Ball screws, Acme screws, threaded rod
    By DJ Morrow in forum DIY CNC Router Table Machines
    Last Post: 03-22-2007, 06:39 PM
  2. Replies: 13
    Last Post: 03-01-2007, 12:28 AM
  3. Belts to replace long ball screws? What are your thoughts??
    By runinbymdnt in forum Linear and Rotary Motion
    Last Post: 02-17-2007, 11:31 PM
  4. Replies: 44
    Last Post: 12-31-2004, 01:54 PM
  5. FAQ's (Motion Transmission,Acme, Ball, Allthread Screws, Cogs, Belts, bearing, etc )
    By chuckknigh in forum FAQ of DIY CNC Machine Building
    Last Post: 04-29-2004, 02:55 AM
