Originally Posted by
martinw
....The mad idea is to put a grid of far more powerful magnets on the MDF base of a Joe-like machine, and hold the workpiece down with magnets from above. You can move the top magnets to avoid the tool path, at any stage of machining.....Martin
I am unwilling to say the idea is totally mad...but here is a reference point...sort of.
We machine 1/4" polcarbonate, about 10" by 12", on a vacuum fixture, this is really machine as in 3/8" cutter engaged full diameter, full 1/4" thickness, 10,000rpm at a feed of (I think) 80 ipm, going around the periphery.
If the vacuum is less than about 20" of mercury, full vacuum is almost 30, we rip the piece off the fixture. Full vacuum is around 14.70psi so 20" is almost 10 pounds for every square inch. If your magnets develop 10 pounds of attraction through whatever is separating them, and you have one every square inch it may work.
ANd after typing this I realised it could be construed as sarcastic but that is not the intent, I am actually trying to give a serious reference point.
EDIT: Correcting typos.
