586,495 active members*
1,685 visitors online*
Results 1 to 8 of 8
    May 2006
    32
    CNC using Bed Rails??
    After several years of reading and watching everyone build awesome machines, I am finally getting off my butt to build a CNC machine.
    I realized I have a ton of Bed Rails sitting in storage. I tried looking for others that used bed rails but only found one reference here:
    http://www.cnczone.com/forums/showthread.php?t=29529
    ...but I don't want to use any wood. All metal and I need to keep the cost low. I am looking at building a 4' X 4' . I really like how Haydn built his:
    http://www.cnczone.com/forums/showthread.php?t=30751
    and would like to do something similar. Anyone know how I could incorporate the bed rails into this project??
    Apr 2005
    3634
    Free DXF - vectorink.com
    May 2006
    32
    your right... man, I am still trying to wake up today...
    2010
    I think you'll find that bed rail is some pretty hard steel, probably approaching spring steel.
    Think about the pounding (no pun intended) it has to take on a nightly basis and keep in mind that some humans have a hoof weight of 300 plus lbs!
    Pretty tough stuff. I remember trying to drill hole in some, once upon a time!
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
    May 2006
    32
    Maybe, I could rent a plasma torch and cut through it. I don't want to spend a huge amount of time/frustration doing the basics with the stuff. Though, it sounds like it would be sturdy enough to do the job.
    2010
    If you use a torch you'll ruin the temper and maybe warp the rails.
    You can use a carbide tipped masonry bit, just sharpen it by hand real carefully or you can get 90 degree drill point end mills economically.
    check page 23 here
    http://www1.mscdirect.com/CGI/NNPDFF?PMCTLG=40&PMPAGE=1
    May 2005
    100
    Maybe a dumb question.....what is "bed rail"?
    2010
    A bed rail is that piece of angle stock that joins the head board to the foot board and supports the springs or box springs.
  1. How many rails?
    By sp1nm0nkey in forum Linear and Rotary Motion
    Last Post: 10-21-2007, 07:47 PM
  2. Design of plasma table, high rails or low rails?
    By Apples in forum Waterjet General Topics
    Last Post: 12-18-2006, 09:21 PM
  3. THK rails
    By wakeboard in forum DIY CNC Router Table Machines
    Last Post: 01-21-2004, 11:13 PM
  4. Anybody seen or used these rails
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 01-20-2004, 10:20 AM
  5. Can I Cut THK Rails?
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-15-2003, 10:45 PM
