586,460 active members*
3,253 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > easy-cnc mechatronics board good or bad?
Results 1 to 16 of 16
    Jul 2005
    65
    Question easy-cnc mechatronics board good or bad?
    I was wondering if anyone has first hand experiance or knows anything of this board. It looks and sounds neat but I dont know anything about what it takes for a good board. It has some features that Ive read on here that are important but would just like some opinions.
    http://cgi.ebay.com/3-AXIS-CNC-ROUTE...QQcmdZViewItem
    http://www.easy-cnc.com/web/download...l3and4Axis.pdf
    Tim
    Jun 2004
    463
    Don't know anything about it, but from the spec's and pictures it looks like it uses the 3977 chips. Doesn't take a genius to design a board with that chip, so should probably work fine. Don't know if that is his normal price, but $100 for an optically coupled 3-axis 3977 board sounds like a good deal even with the $20 shipping.
    Jun 2003
    3312
    A negative on the board is it uses a socket for the 3977. Socketing is not recommended by Allegro, the manufacturer of the 3977 chip. One of the significant reasons the chip is not recommended to be socketed is that heat transfer is through the 9 ground pins of the chip. The heatsink shown on the chips is conducting heat through the plastic body. While that helps, plastic (IC package) is a poor thermal conductor.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Jul 2005
    65
    Thanks guys for the replies. So would adding some fans on the heatsinks like processor in a computer help? I take it the 3977 chip is a fair chip. Also would there be any need for anyother boards to go along with it ( this is a stand alone board )? And would it work well with some keiling @ 300 oz/in 8 wire motors (I have a chance to get some)?
    Thanks again
    Tim
    Nov 2005
    10
    I have been using his 4 axis board with 425oz motors for quit some time and have had no problems with it. Works quit well. Price is not bad either.
    Jeff
    May 2008
    Hello everybody,
    Socketing is not recommended by Allegro, but I have a test board from Allegro and it has an A3977 in a socket. I purchased a Mechatronics board unfortunately I damaged one axis, while I was replacing the IC I noticed that Mechatronics sticks with a termopad a little metallic slug between the IC and the heatsink and the heat doesn't damage the socket. I am so happy with my driver board, it stills running whithout any problem.
    Jun 2008
    1082
    This is good news! I am a big beginner and this is the board I chose as well. I also picked up some 400 oz-in Keling 34 motors on "sale". I can't wait to start playing with 'em
    Aug 2009
    it's a bad design, mine fried, SOCKETS SHOULD NOT BE USED on this Alegro Chip IT OVERHEATS and dies
    Feb 2009
    15
    I've got one of easy-cnc's 3 axis boards and the only problem I'm having is not so much with the board but neither easy-cnc or Mechtronics will answer emails. I've been looking to buy the 4th axis extension board but they just will not reply to my emails. If they won't answer questions about buying their stuff I can only image how bad they would be to answer technical questions.
    Apr 2007
    327
    The board is basically a piece of crap and the support is non-existant - nuff said...
    Sep 2009
    15
    I bought one of these easy-cnc boards from ebay. It was shipped fast, and it was easy to hook up and get running.
    I am having problems with my motors freezing, but I am pretty sure the cause is the plasma cutters high frequency arc. I sent them an email and got no reply.
    I recently ordered a relay board from the easy-cnc website. I have been waiting 3 weeks, and still don't have it. I sent two emails, and got a form letter back saying it take 7 to 15 working days to get the board. (same letter on both attempts).
    Don't buy if you are in a "hurry" (3 weeks), or if you think you might have a question.
    I do like the optic coupling, the on-board fuses, and seperate amp control for each axis for both running and idle. he documentation is reasonable.
    The relay, if I ever get it, features optic coupling, and two relays that can be configured seperately or together, and are solid state capable of switching 220 volts. Nice, if you need that. If I had it, I could be at my shop playing.
    one thumb up, one down.
    Jul 2008
    139
    Old thread I know, but thought I'd give a bit of feedback - I bought this board a couple of years ago when I was clueless...Is still am, but I can report that I've fried about FIVE A3977 ICs during the time I've owned it. Two of these were probably down to my fault (bare pcb base touched something metallic etc)...but he other three...hmm.
    Of course swapping out the A3977 on this board is a breeze since they're socketed, but at $10 a pop (delivered) having these ICs fry so frequently is wearing a bit thin.
    My only other board to gauge this one against is a cheap Chinese TB6560 variant.....that chinese one is awful and makes the mechatronics one appear ooze quality by comparison!
    Jun 2003
    3312
    Couple of points, the A3977 DOES NOT TOLERATE anything over 35V, and that includes back emf. So Practically don't run it at more than 27VDC power supply voltage. 2nd, you might get some thermal adhesive and glue a heatsink to the 3977. Something that has verticle height and plenty of fin area to pull some heat out of the chip.
    May 2005
    1397
    Quote Originally Posted by HankMcSpank View Post
    Thanks for PMinMO for pointing out why the A3977's are frying: Heat will get them every time in that design since there is no heatsink! Controlling lots of power, especially if you are doing it in microstepping modes, will cause any controller to heat. I can't imagine why the designer didn't account for that.
    And then there is the garbage TB6560... Don't even get me started.
    These people selling junk really tick me off. It's driving people away from the hobby by giving them a bad experience and wasting their money and time. We need a "protect the newbies" campaign to keep people from making that mistake with their first purchase.
    Jun 2003
    3312
    The TB6560 itself isn't a bad chip, it's the board designs that turn it into crap...
    May 2005
    1397
    Quote Originally Posted by pminmo View Post
    Yeah, I should have been more clear. Although... I've been given to understand the TB6560 is a little light on self protection... e.g. not terribly rugged.
    How do you feel about that open source TB6560 design you have on your site? Is anyone using it? Is it "hardy"? It looks like it would be a bit easier to repair than most of the junk boards from China.
  1. mechatronics v-ref
    By apex in forum Controller Cards
    Last Post: 12-13-2007, 02:02 AM
  2. Easy way to tell if the motor is good
    By journeyonline in forum Stepper Motors / Drives
    Last Post: 11-22-2007, 06:17 AM
  3. Mechatronics controller blowing fuse!
    By WilkBoy in forum Stepper Motors / Drives
    Last Post: 06-25-2007, 03:43 AM
  4. HCNCPRO board good for these steppers?
    By mind_nl in forum Hobbycnc (Products)
    Last Post: 03-31-2007, 10:31 PM
  5. Good, Easy to machine Steel (not 12L14)?
    By Builder4wd in forum MetalWork Discussion
    Last Post: 09-25-2006, 03:33 AM
