586,035 active members*
3,648 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN E-serie (MITSUBISHI system)
Results 1 to 11 of 11
    Jan 2008
    4
    Hello everyone! I’ve question about programming this machine (MITSUBISHI system), what function I must use too drill through hole by cylinder. The spindle must be STOP, and movement on axis X & Z, using the angle holder. thank's for answer.
    Jan 2008
    8
    If the spindle is stopped and you are using the #1 Turret with X and Z, it would be G711. If you use the upper, or #2 turret, it woudl be G712.
    Oct 2007
    24
    I use this program for the angle drill holder but its for drill on the sub side and I am only going half way thru.
    G630
    G632
    (0.125 70DEG HOLES 0.600 DRILL PT TO COLLET )
    M48C0
    T2500
    G50U-0.850W-2.545(tool shifts)
    G98M83S4=4500
    G0X0.449Z0.129T25(x start point and z start point)
    /B4
    #100=0
    WHILE[#100LT360]DO1(i am drilling 4 times "loop")
    G0X.449Z.129
    C#100(changes #100 = to C axes Deg)
    G1A-70.0X0.300F5.0
    G0X0.449Z0.129
    G1A-70.0X0.0F5.0
    G0X0.449Z0.129
    #100=#100+90
    END1
    /B4
    G0X0.600T0
    G50U0.850W2.545
    M85
    G99
    Oct 2007
    24
    if you want to use it for the front turret on guide bushing it would look like
    $1
    G610
    G620
    G610
    $2
    G610U1W1
    G620
    M18C0
    T2500
    G50U-0.850W-2.545
    G98M83S4=4500
    G0X0.449Z0.129T25
    /B4
    #100=0
    WHILE[#100LT360]DO1
    G0X.449Z.129
    G1A-70.0X0.300F5.0
    G0X0.449Z0.129
    G1A-70.0X0.0F5.0
    G0X0.449Z0.129
    #100=#100+90
    END1
    /B4
    G0X0.600T0
    G50U0.850W2.545
    G0X7.05
    M85
    G99
    G610
    make sure on $1 right before you want to drill make sure you stick the Z out cause on G620 the turret is going to position for Z. Just look up G620 in win-cnc. The reason i wrote G620 its because on the citizens they use the G600 codes. If you have one that is older the G610 & G620 would be G710 and G720
    Oct 2007
    24
    Sorry please don't forget to que up $3 also
    Jan 2008
    8
    Yes and no.... on E series they use G700 commands, so your G610, G620, would be G710 etc.
    Secondly, if you stick the part out to do the angle work, then Superimpose G(7)620, then yes, you can do it this way, but if you are simply drilling with turret, whether it be angled or straight face, you could use G610 (G612) just as easily.
    Jan 2008
    8
    Also, in G620,720, you need to have ths stock stuckout far enough so that you can do the work. If you do this in G710, you use Z1 in conjunction with the X axis of the turret you are using, and in this case, lets say the upper one, #2. I can't read you rprint, but lets say it is a 80 degree angle. Set your tool at 80 degrees and program away, but it would look like this:
    $1
    G710U1W1
    G712
    T2200
    M5
    M18C0
    G50W U (uSE APPROPRIATE SHIFTS FROM pRESETTER)
    G0X#814+.1Z-.1T22
    M80S3=2000
    Z.5
    PROGRAM YOUR DRILL HERE
    G0X#814+.5T0
    M82
    G50 CANCEL SHIFTS
    G700, OR WHATEVER MODE YOU CHOOSE TO GO TO
    $2
    G710
    G700
    $3
    G710
    G700
    Jan 2008
    4
    Thank YOU all for answer! could You tell me what's the parametr A?
    Oct 2007
    24
    G710U1W1
    ON $1 I WOULDN'T START OUT WITH G710U1W1, I WOULD UNDERSTAND
    G710U1 TO MOVE X ALL THE WAY HOME BUT NOT W1.
    304
    Correct
    You would NOT use "W1" in $1 or the stock will go back toward your barfeed and if you have a full length bar you will move the barfeeder or the machine. Something will give!
    Oct 2007
    24
    what do you mean by parametr A? in my program A would be the angle you are trying to drill at. you just to draw it the part out and figure you start and end point for z. you position x and z start point then you would go A-45 X.??? if you are drilling a 45 deg angle. then just go back to your xz start point the go back in A-45. X.???. in my program i am using an endmill due to the problem that i was getting a real bad burr with a drill and i only did it in two passes to break thru the i.d.
  1. Citizen CAV barfeeders
    By EdgeCrusher in forum CITIZEN Machines
    Last Post: 09-26-2017, 12:51 PM
  2. FANUC,HAAS,SINUMERIK,MITSUBISHI CNC system Simulation
    By ziyoo in forum News Announcements
    Last Post: 08-03-2012, 05:55 AM
  3. RFQ - Mitsubishi Spindle Controller & Numerical Control System
    By cee in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-23-2007, 06:27 AM
  4. VM serie machine owner?
    By Wiseco in forum Haas Mills
    Last Post: 05-01-2007, 07:51 PM
  5. Z-axis Problem Bridgeport CNC serie 1
    By Rufan in forum Bridgeport / Hardinge Mills
    Last Post: 08-10-2005, 02:31 AM
