586,119 active members*
3,517 visitors online*
IndustryArena Forum > CAD Software > Solidworks > gear making tool or wizard of some sort
    Sep 2007
    84
    gents,
    i have drawn some spoked gears ect . is there a tool to make the teeth other then drawing one tooth and then copying it in a circulur pattern. i looked in the tutorial and help by topic but only found gear mating
    ty
    craig
    Jan 2008
    83
    use your design library's toolbox and pick either the metric or inch folder, then powertrain components, gears and right click the type; hit create part and fill out the fields and "OK" to create it. We use this a lot to create and download the part into our CAM software to machine plastic gears and sprockets.
    Jan 2008
    GearTrax by Camnetics (http://camnetics.com/) is probably what you are looking for.
    Their gear making plug-ins for SolidWorks are just amazing.
    Andrew
    Jan 2013
    9
    Any have turtorial for geartrax? tnx
  1. Tool Offsets - What's wrong with this Gear?
    By edo in forum G-Code Programing
    Last Post: 09-25-2012, 03:46 PM
  2. tool making technique
    By sharathchandar in forum MetalWork Discussion
    Last Post: 10-25-2007, 02:05 AM
  3. My TL15 clunks then making a tool change
    By APP in forum Haas Lathes
    Last Post: 08-28-2007, 05:15 PM
  4. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
  5. Anyone Know a know of a good book for mill, tool making?
    By sendkeys in forum MetalWork Discussion
    Last Post: 11-02-2004, 04:56 AM
