586,655 active members*
3,117 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > replacement windows for VF3 door
    Feb 2006
    49
    What's the cheapest way to replace the door windows on a yr 2000 VF3?
    Someone squirted acetone on our while trying to cleanup and they look vandalized now so I need to replace them.
    Should I buy them from Haas, or is it alot cheaper to measure them and get the local plastic shop to cut up some Lexan the right size. Does anyone have the dimension handy for the windows?
    Thanks in advance for your help.
    Doug
    Atlanta
    Jul 2005
    12177
    Take yours out and take them to a local plastic shop...or buy a sheet of Lexan and cut them yourself. It is simple to work with using a table saw and a saber saw with a sharp coarse tooth blade for curves.
    One piece of advice: Do not, repeat DO NOT get convinced to buy the Lexan with the abrasion resistant coating. The coating makes it much more brittle and you have lost a large safety factor.
    Sep 2006
    251
    wddanie,
    Price check the lexan first. Where I am from a sheet of lexan is $286.00 and I have to machine it to fit. I can buy them from HFO for $83.00 per window. My vote is to buy from HFO. Price check first!!!
    Just a good ol' boy, never meanin' no harm.
    Joe
    Feb 2006
    49
    Thats a nice tip. I would have probably gone with the anti abrasion coating.
    Doug
    Jul 2005
    12177
    Quote Originally Posted by JoBwan View Post
    wddanie,
    That is a good point. I guess my view is biased; we buy Lexan a 5 or 10 sheets at a time and get a much better price than that. Also have a GR510 which helps a little bit with the machining.
  1. Door interlock?
    By Edster in forum Fadal
    Last Post: 07-12-2014, 06:40 PM
  2. Door Not Opening
    By WASLYH in forum Fanuc
    Last Post: 10-31-2007, 09:09 PM
  3. Looking to get my foot in the door!
    By Tim Wiltse in forum Employment Opportunity
    Last Post: 09-17-2007, 01:31 PM
  4. Looking To Get Foot In Door
    By GANDY505 in forum Employment Opportunity
    Last Post: 06-05-2007, 05:28 PM
  5. Windows XP or Windows 2000 better with Mach2
    By Beezer in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2004, 04:08 PM
