586,530 active members*
2,796 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > automating the gecko reset button on power up
    Aug 2006
    281
    Anyone come up with an easy way to do this? I'd rather not have two power switches. I'd also rather not build a timer circuit just because I'm not really good at it and it's a pain. I'm getting a little burned out on this conversion as it is. lol
    I was thinking I could probably use a relay and a capacitor and feed the coil in series with the cap so when the cap charges it will drop the coil. I've done this before for a time delay in a car and it worked OK, but 5 seconds is a pretty long time.
    It may require a resistor for discharging when the relay is not engaged.
    Any thoughts?
    Aug 2006
    281
    I do want to add, I've read the Gecko instructions over and over and it doesn't say there's a problem with just leaving err/res connected to enc+ (+5vdc I assume) as long as you don't plan to use it as an fault output.
    I was told on the Yahoo groups that I shouldn't do this. Can anyone comment on this?
    Mar 2004
    1806
    Chris64,
    On my machine, I have a manual reset button that is tied in to do this function. I hold it in for the required time and off we go. There have been times that I have had a drive fault out (thank goodness) and I push the reset button and off we go again. Also, I personally prefer this so I can make a last minute check before engaging the controls.
    If you leave the resistor tied in and have a fault while running, it will reset and possibly try to move on. This could be disastrous if you have hit a hard limit and could possibly cause damage!
    I have had occasion to fat finger a MDI command and drive my vice into the column as there is overhang on the back of the table. I would hate for it to sit there and keep trying to do that over and over:{(
    Art
    AKA Country Bubba (Older Than Dirt)
    Feb 2007
    12
    Chris64,
    I left my ERR/RES tied high, and I have now got three out of four blown G320s. I don't know if these two facts are in any way connected, but I'm now looking at doing what I can to make my system more robust, while I wait for Gecko to look at my drives.
    I agree with CB. I sympathise with your desire to get it done, but if you cut corners (as I did) it will likely take you longer and cost you more in the future, while you fix your damaged system.
    I hope that this helps.
    Leo
  1. Replies: 21
    Last Post: 03-09-2012, 02:54 PM
  2. On an OT control, hitting the reset button
    By g-codeguy in forum Fanuc
    Last Post: 06-14-2007, 05:21 AM
  3. Question on made gecko error reset controler
    By Cudel Frederic in forum Gecko Drives
    Last Post: 08-08-2006, 08:54 AM
  4. Gecko Error/Reset controller with 16C55
    By Cudel Frederic in forum PIC Programing / Design
    Last Post: 08-05-2006, 04:30 PM
  5. (Bridgeport w/ Heidenhain) Yellow Power Button Failure
    By griffithbuilt in forum Bridgeport / Hardinge Mills
    Last Post: 04-14-2006, 08:45 AM
