Is there a radio button or checkbox that will cut the block numbers (N102 for example) on or off. My mill code posts with block numbers, but my lathe doesn't. Is that post processor driven?
phoodieman
phoodieman
You can turn the sequence numbers on/off in the post. Under the heading General Output Settings look for omitseq and flag that with yes or no (no you get sequence numbers)
Good Luck
Worked like a charmmmmmmm
thanx....
phoodieman
