586,071 active members*
3,756 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Material for Rocker Shafts
Results 1 to 6 of 6
    Dec 2006
    11
    I am making a set of roller rockers for my car as a spare time project. Not looking to sell them or any thing so cost is not an issue I just want to do it right. My question is what my material of choice should be for the shafts. I was looking at some of the rocker manufactures websites and noticed either 4340 or 8620 steel was used. What is the difference between these two steels.
    I know 4340 can be threw hardend and 8620 is case hardened. What will be better as far as stregth/wear. The shafts will have needle bearings riding on them.
    I also heard H13 tool steel is suppose to have a high shear strength at high operating temps. I am not sure of the cost on this stuff but it could be a option as well. Thanks for the help.
    Jul 2005
    12177
    You have been around for a year or so, have you seen any posts by NC Cams? He seems to be absent lately but he would be the one to give you the definite answer; maybe find his signature some place and send a PM. And I hope he doesn't object to a suggestion like this.
    Dec 2006
    11
    Yup. I was hoping he would show up. I will wait a bit before I bug him with a PM. Meanwhile does anyone else have any suggestions?
    Mar 2006
    2712
    Are you going to have the needle bearings running directly on the shaft? If so, check the hardness required for the needles to run on and lube requirements. Like Hu suggested, I,d PM NC Cams, just don,t ask for cam grinding "trade secrets". lol
    Dick Z
    DZASTR
    Jul 2005
    12177
    Quote Originally Posted by RICHARD ZASTROW View Post
    .... Like Hu suggested, I,d PM NC Cams, just don,t ask for cam grinding "trade secrets". lol
    Dick Z
    Whadda ya mean "like Hu"???????????
    Mind you if that was a slip of the mind that indicates who and what are connected to who and what in your memory I am extremely complimented.
    Mar 2006
    2712
    Geof, Sorry 'bout that. Just confused while associating great minds in a common file. lol
    Dick Z
    DZASTR
  1. Machining an aluminum rocker arm for pulling tractor
    By jpcuttergrinder in forum MetalWork Discussion
    Last Post: 03-03-2016, 01:18 AM
  2. RFQ for 3/8 dia x 11.4 long cds shafts
    By mcmmach in forum Employment Opportunity
    Last Post: 09-21-2005, 10:40 PM
  3. sagging shafts
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 07-02-2005, 04:05 AM
  4. Questions about shafts
    By andy_ck87028 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-14-2005, 12:21 PM
  5. Shafts or rails?
    By sjmarsha in forum DIY CNC Router Table Machines
    Last Post: 06-30-2004, 12:49 PM
