I should mention I also looked at the NEMA-34 motor. It is a dog at 7.7mH. What makes a dog or a non-contender is motor inductance apart from everything else. Let's churn the numbers: Vmax = 32 SQRT mH. That makes the maximum supply voltage 89VDC and it's beyond any of our drives. That makes the corner frequency at 789 RPM and peak power output of 253 Watts. Way beyond what a G250 can do and just barely beyond the reach what a G203V can do. You want big power from a big motor? Use a G203V. Big motors need big drives.
Little drives work best with little motors. Little drives also cost less than big drives. Little motors still put out really decent power with little drives.
Have a sense of proportion: Nearly everyone emphasizes holding torque when they mention a motor. It is nearly the most useless specification available. It is silly and naive. A rusted bolt has 10s of thousands in-oz of 'holding torque'. What makes it different? The difference is there is zero speed associated with it. If you get anything, get this: only POWER GETS THINGS DONE!!. Power is torque times speed. Torque is meaningless without an associated RPM. Holding torque is just that; torque at zero RPM. No power at all at zero RPM.
Drives move motors and motors develop power. Power is always a product (torque * RPM) of torque and speed. Power is work and it's expressed in Watts. You have a milling machine? Power is how many chips of hot metal it carves away. You have a plasma cutter? Power is how quickly it can accelerate from one point to the next.
The G250s are very small drives. They optimally power motors to the tune of 100W or so. The best Olympic trained athlete can crank out about 100W of power long term. The 26-mile Marathon kind of endurance. I have seen more than a few machinists working on manual Bridgeport sized machines. None of them looked like they were Olympic quality athletes. 100W of power into a benchtop sized machine should be more than plenty for everyone.
You need more than that? Don't be cheap. Buy a bigger drive.
Mariss
