PLEASE READ FIRST BEFORE USING THE G201
Before you start, you must have a suitable step motor, a DC power supply suitable for the motor and a current set resistor.
The motor’s rated phase current must be between 0.3 Amp and 7 Amps. The power supply voltage must be between 4 times and 20 times the motor’s rated voltage. The current set resistor may be a 1/4 Watt, 5% part. Finally have a STEP and DIRECTION pulse source available.
PLEASE READ FIRST BEFORE USING THE G202
PLEASE READ FIRST BEFORE USING THE G203V
Before you start you must have a 2-phase hybrid PM step motor, a DC power supply suitable for the motor and a current set resistor.
The motor’s rated phase current must not be more than 7 Amps. The power supply voltage must be between 15VDC and 80VDC unregulated. The current set resistor may be a 1/4-Watt, 5% part. Finally have a STEP and DIRECTION pulse source available.
PLEASE READ FIRST BEFORE USING THE G210
The motor’s rated phase current must be between 1A and 7A, or 0.3A to 2A for the low current range. The power supply voltage must be between 4 times and 20 times the motor’s rated voltage. The current set resistor may be a 1/4 Watt, 5% part. Finally have a STEP and DIRECTION pulse source available.
PLEASE READ FIRST BEFORE USING THE G212
