586,408 active members*
2,850 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Dec 2006
    603
    Hole drilling help
    I have to drill 2 - .3125 holes in 1 inch aluminum round bar. These 2 holes need to be dead center and exactly 90 degrees apart and do NOT intersect.. I have made 2 attempts and the closest i came was a 4 degree error. The drill seems to be drifting.
    Any tips or tricks. Should i drill small and try a reamer? Maybe drill with a smaller drill to pilot and then step up to the 5/16?
    Dec 2004
    524
    Assuming you have proper tools and fixtures, this should not be an issue.
    Why don't you tell us how you are doing it?
    Hint #1 if you are using a stub drill, it can't possible bend by 4 degrees. How are you holding the rod and how are you rotating it 90 degrees?
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Dec 2006
    603
    Quote Originally Posted by lerman View Post
    Ken
    I am holding the rod horizontaly in a rotary table with a chuck mounted to it. Getting 90 degrees is easy but the drill seems to be drifting.
    Someone mentioned a screw machine bit would be a good choice along with spot drilling before hand. Another mentioned pre-drilling with a smaller drill and then finishing with the proper drill or an end mill.
    What effect does drill RPM play here?
    What do you think about
    1. Indicate along X axis, find center, and Spot drill
    2. Change mill to highest RPM possible
    3. Drill thru with a .250 drill bit.
    4. Finish with a .3125 2 flute endmill chucked in a collet.
    Bad idea? Should i finish with a .3215 drill?
    Dec 2005
    1408
    Quote Originally Posted by stevehuckss396 View Post
    Dear Steve,
    No expert, but here is what has worked for me in reasonably low precision applications, eg drill press stuff.
    Drilling into round stock is a problem. You really must hold it securely.
    The drill tip will skate everywhere if it has nothing to centre on.
    IMVVHO, start with a centre drill. I nice big fat one. It will not wander. You only have to drill deep enough to provide a guide for the point of the next tool. Do not move the workpiece, and put your 0.3125 drill in the chuck.
    When it comes to 90 degree alignment for the next hole, there are better men than me hereabouts.
    Best wishes,
    Martin
    Oct 2006
    48
    Are you center drilling before using the drill bit?
    Dec 2006
    603
    Quote Originally Posted by Gary55Ford View Post
    I am now!! (Grin)
    Dec 2004
    524
    Another trick is to use a center cutting end mill to put a small flat on the rod before drilling.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
    Sep 2007
    89
    I had a job a few years back drilling in I think about 3/4 maybe an inch aluminum rod I remember doing a few hundred of those suckers anyway the operation I had to do was
    1. Center drill with an over size drill like mentioned above by martinw
    2. Drill with a stub drill I think about .050 undersize
    3. Then with a two flute endmill in a collett not a drill chuck about .015 undersize
    4. Finish with a reamer not pushed all the way in the collett maybe about an inch so it can float a little
    Maybe someone else would have better input on rpm but I would probably stick around 700- 900 rpm for drilling maybe 300 for reaming It does just suck switching from drill chuck to collett but once you get a rythm probably chuck out 80-100 in ten hours
    Jan 2006
    2985
    If you are having problems after the above suggestions, an endmill as the finish tool can help as it does not wander. if an end mill tried to wander, it would cut and then come back to center. a drill cqan be pushed from side and move the hole over. An end mill will just cut on the side.
    Matt
    Dec 2005
    1408
    Ken
    Dear Ken.
    Yes indeed. I do not have a milling machine but I've hand filed a small flat on small diameter workpieces to discourage the drill from wandering.
    Best wishes,
    Martin
    Dec 2005
    1408
    Quote Originally Posted by martinw View Post
    Dear Ken.
    Best wishes,
    Martin
    Dear Ken,
    This is slightly "off-topic", but putting a small flat on equal angle aluminium or steel profiles works well too if you want to drill a hole at 45 degrees to the section axes, and on the "point".
    Sorry, machining experts (amongst whom I not numbered) will know this already. I was thrilled to discover this for myself a few months ago.
    Best wishes,
    Martin
    Jan 2008
    85
    Steve most errors can be found in the setup.
    How deep are you drilling as well ?
    1. Recheck your setup with a test indicator while your material is being held to ensure your rod is being held in alignment of your Z axis.
    2. Ensure your drill surface is prepped with a flat surface and use a center drill to start.
    3. Drill undersized leaving about .015 on the diameter.
    4. Bore or use a Boring endmill with a G85 (bore in and out) to finish the hole to size this will take out any wandering of the drill or reamer for that fact.
    5. when you rotate 90 degrees check with your indicator to ensure your table has located properly. (I have been amazed on how many tables are warn and do not locate properly).
    Never assume that a chuck or another holding device is right on the money, use that indicator so you know, once you verify then you're off and running.
    Hopefully this will help.
    not met to offend anyone but to ensure understanding I post the following.
    (a reamer will only follow the hold that is made for it)
    (boring endmill is ground so that only a small portion on one flute will be cutting)
    (G85 can be used with a L2 or L3 (repeat) command for tight tolerance holes for repeatability)
    My Response to "It's Close Enough", "Is Your Tool Box and The Door Close Enough?"
    Dec 2006
    603
    Well this is what i tried.
    Indicated along the front to align with X axis
    I indicated along the top to make sure i was parallel to the table.
    Found center
    Spot drill
    Drilled thru with a .125 drill
    Drilled thru with a .250 drill
    Drilled thru with a .3125 end mill
    I wont know for sure until i try the part at work but i slid some ground stock thru the holes and put a square up to the stock and it looks one heck of alot closer than my first try/failure
    Thanks for the suggestions folks. Things like this are second nature to you guys but still very complicated to me. Thanks for your patiance.
    Steve
    Jul 2005
    12177
    Just a comment: If you were doing this on a production basis where seconds count in the cycle time; skip the center drill and .125" pilot drill and just go straight through with a stubby .250" drill held in a collet, not a drill chuck, then the .3125" mill or the mill ground as a boring tool. The center and pilot are mostly redundant when you have .0325" leeway between the drill and final bore size
    Jan 2008
    85
    Found center
    Spot drill
    Steve
    You will have good results with a drill size just under finish diameter as well and if you use a stub drill, alot of times center drill can be done away with, so you will have a stub drill and a boring endmill.
    Jul 2005
    12177
    Quote Originally Posted by dapoling View Post
    Mind reading or great minds think alike?
    Jan 2008
    85
    Quote Originally Posted by Geof View Post
    LOL must have been responding close to the same time, I did not see your post to just now.
    I agree with your idea Geof
    Sep 2007
    89
    I agree with dapoling I wasn't trying to imply that a reamer would straighten a hole it will follow the existing hole like he implied. ( didn't want to confuse anyone starting out) thanks for pointing that one out dapoling.
    One more thing I would like to add is what is everyones thoughts about the effectiveness of peck drilling for the straightness of a hole.
    Stevehucks396 I don't know what your experience is but I've just came to grips that it may take a few scrap parts to get the process right. I used to freak out that I scrapped a couple of parts and I would get fired on the spot but as long as a prepared myself for this and cut some extra stock for a couple of mistakes the job would still get done on time and maybe the scrap parts will work for setup pieces on the next job. I work with a couple of guys with many more years experience than me and I would say it is somewhat common that they have one setup part to prove a process out.When I first started out I just assumed that experienced machinist never ever made mistakes (made me nervous) but once you see them make a mistake once in awhile you realize there just like anyone else. It is pretty amazing if you anticipate this you keep your anxiety down and you usually can see exactly what went wrong after awhile you can foresee something will go wrong ( but you probably try it anyway and hate yourself later).
    Dec 2006
    603
    That makes sense. It is not a production part but no reason to waste a few steps.
    Dec 2006
    603
    Quote Originally Posted by bigtoad170 View Post
    My experiance is 1-1/2 years of tinkering in the garage. I build small engines that run on compressed air. I rarely make a perfect part but they are getting better and better.
Page 1 of 2 12
  1. Deep hole drilling
    By kalmah in forum MetalWork Discussion
    Last Post: 02-27-2013, 11:17 PM
  2. Precision hole drilling?
    By sp1nm0nkey in forum MetalWork Discussion
    Last Post: 11-20-2007, 07:30 AM
  3. Drilling a .010 hole
    By CoolhandLuke in forum Uncategorised MetalWorking Machines
    Last Post: 03-26-2007, 04:44 AM
  4. Drilling a hole in a 3D model
    By mayhugh1 in forum SprutCAM
    Last Post: 10-25-2006, 05:51 PM
  5. Deep hole drilling on OKK
    By eddie in forum G-Code Programing
    Last Post: 09-22-2005, 12:55 AM
