586,096 active members*
3,687 visitors online*
Results 1 to 6 of 6
    Jan 2008
    7
    Bridgeport/ROMI EZ Path Lathe
    I do not have possession of this machine yet but will soon. I was wondering if anybody has tried/been successful in getting a CAM to talk to the controller. I use MasterCam but do not have a seat for lathe so I'd like to get some input from experienced folks before I go down that road.
    TIA
    Dec 2006
    51
    I've used cam for an Ezpath SD (the last version made) without any problems, I used feature cam, but really the Control is conversational and so easy to program you don't need to cam it. I think I actually have an Ezpath post for Mastercam 9 but I don't have a lathe licence to give you.
    Let me know if you have any questions about the control or programming.
    Jan 2008
    7
    Thanks - the people over at EMI also have a solution so between you and EMI I think I will be covered.
    Jan 2010
    Mastercam and Bobcad have posts for EZPath. I was and still am a Service Tech for
    Bridgeport, Hardinge, Cincinnati, Mori Seiki, Lagun, Trumph, Daiwoo, Shizouka, Kuraki,
    Takisawa and Mitsubishi (I have worked for a half dozen different distributors). I can even help you with a Tosnac. Which means I've been factory trained for Fanuc, Siemens, Heidenhein, Yakawa, Mitusbishi, Okuma, Trumph Vectormark, and ESAB. I also have training on Webb - yes, I'm older than dirt. If you don't get carried away - the answers are free.
    -KB
    Nov 2012
    bridgeport ROMI lathe problems--I need help !!!
    I have a problem where the machine will power up as normal, the machine references as normal, I can then rapid the saddle, load a program etc but the spindle will not start.
    You can hear the brake release when the start button is pressed.
    The rpm comes up on the screen as I turn the chuck manually.
    I can manually operate the contactor and the motor runs.
    Guard relays show all lights as they should
    On the AUF board LED D11 is solid on and D12 is pulsing?? any ideas?? Please
    Jul 2006
    103
    Quote Originally Posted by msdltd View Post
    I would suggest you start another thread with some specific info on the machine in question. We have three ez-path lathes and they are all a bit different, the powerpath is a totally different animal.
    "those who would sacrifice liberty for security deserve neither" Benjamin Franklin
  1. Bridgeport/ROMI Engine lathe
    By smittys800 in forum Bridgeport / Hardinge Mills
    Last Post: 04-14-2009, 03:02 PM
  2. EZ Path Bridgeport lathe
    By ruger2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-31-2007, 07:33 PM
  3. Need HELP on Bridgeport EZ-Path ROMI Lathe
    By Michael Esch in forum DNC Problems and Solutions
    Last Post: 04-10-2007, 04:38 AM
  4. Romi EZ Path Lathe
    By kenski in forum Uncategorised MetalWorking Machines
    Last Post: 07-22-2006, 03:25 AM
  5. Manual needed to Romi/Bridgeport CNC lathe
    By mgreene in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2005, 09:20 PM
