586,116 active members*
3,442 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > What is best for sheet metal part modeling?
    Sep 2005
    221
    We do a lot of sheet metal stamping die design, and have to bend, unbend parts with ribs, flanges etc. I would like to start doing in Solid modeling, but
    have found the autocad surfacing/solid modeling to leaves a lot to be desired.
    Looking for what CAD software is the best for this type of Modeling.
    The inherent ability to unfold, develop blanks would be good also...
    Thanks for your help!
    Jan 2004
    3154
    SolidWorks
    www.integratedmechanical.ca
    Jul 2004
    31
    +1
    Quote Originally Posted by DareBee View Post
    SolidWorks
    Oct 2006
    8
    Look at www.forming.com. I used a demo version of the forming suite to create a flat pattern of a project. The software is used in the auto industry and seems to be quite good.
    Aug 2006
    231
    sheet metal
    Solid Works and ProE both have strong sheet metal tools. But costly
  1. big problem sheet metal
    By fsa in forum Mechanical Calculations/Engineering Design
    Last Post: 11-17-2007, 11:51 PM
  2. Sheet Metal Countersinks
    By kchritz in forum CNC Tooling
    Last Post: 10-25-2007, 04:17 AM
  3. Help Modeling a Part w/ Complex angles
    By nlh in forum Uncategorised CAD Discussion
    Last Post: 09-20-2007, 10:31 PM
  4. Bit recommendation for sheet metal
    By adda in forum Uncategorised MetalWorking Machines
    Last Post: 01-26-2007, 08:50 PM
  5. Thin sheet metal
    By itsme in forum Welding Brazing Soldering Sealing
    Last Post: 03-01-2005, 10:24 PM
