586,116 active members*
3,440 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to convert Manual Lathe to CNC Lathe?
    Jul 2007
    How to convert Manual Lathe to CNC Lathe, without purchasing kit if possible. I am new in this matter.
    24221
    For one, you will need to replace the Acme screws with ball screws, there has been several past threads here covering the steps for the conversion procedure.
    Al.
    Albert E.
    Sep 2006
    177
    You'll also need servo or stepper motors and a drive for each motor. It's good to have a servo spindle too, but this isn't a necessity.
    Sep 2006
    607
    You dont need a servo spindle. What you "need" is an encoder so that it knows at what speed its turning. If you want to do milling jobs on the lathe with live tooling, you should consider making it sort of a servo with a break.
    You can even do with regular Acme screws, but there are more friction in them, and they have more backlash.
    Other then that, you will need (as mackeym allready pointed out) servos or steppers with drivers (one for each motor), and a powersupply. You will also need a breakout board for connecting the drivers to a computer.
    Jul 2007
    Thanks, Al The Man, mackeym and The Blight for your replies. I have search the net for this and found following artical useful :
    http://www.dakeng.com/CNCconvert.html
    But I need more detailed, information for the same.
  1. manual lathe convert cnc/manual lathe
    By kakayo in forum Vertical Mill, Lathe Project Log
    Last Post: 02-21-2010, 08:13 PM
  2. Convert Taig Mill into lathe?
    By youthebest in forum Taig Mills / Lathes
    Last Post: 11-20-2007, 03:26 AM
  3. Convert a lathe to a cnc lathe
    By Tompie in forum Uncategorised MetalWorking Machines
    Last Post: 09-21-2006, 02:41 PM
  4. Lathe: convert PULLEY to GEAR?
    By lepton in forum Mechanical Calculations/Engineering Design
    Last Post: 12-13-2005, 06:22 PM
  5. Lathe:convert PULLEY to GEAR?
    By lepton in forum Mini Lathe
    Last Post: 12-13-2005, 06:19 PM
