586,106 active members*
3,013 visitors online*
Page 1 of 5 123
Results 1 to 20 of 92
    Hoss Mill Console Project
    This project will be a new Mill Console to house all of the mills electronics, switches, power supplies, monitor, keyboard etc.
    The only components not included will be the actual Windows PC.
    I want to keep it separate so that I could easily upgrade the PC down the road.
    I'll be using some stripped frames from a few old towers that have piled up over the years.
    Finished dimensions will be about 24x21x14.
    I'll still use my original control panel with it, but probably change some of the switches.
    I want to add a Manual Pulse Generator too.
    The joystick is nifty but the MPG will be more useful.
    All of the panels on the face will be removable so that I can change my mind
    and reorganize the switches and such if necessary. It's bound to happen.
    I've been putting this off for a while because the details weren't coming.
    Usually ideas will just come to me while driving home, just before bedtime, dropping a deuce, etc.
    I'll make notes and figure it all out later.
    I mull over a few options but If I don't like any of them, I just wait.
    Eventually it just hits me.(nuts) and I get to work.
    Time to get to work.
    I have a video showing the cutting of the keyboard and monitor panels using the flood coolant for the first time.
    Went OK, does need a tweak or 2 to the strainers, they clogged a little.
    Shows the benefits of the extra capacity of the X and Y travels.
    Later Hoss
    Attached Thumbnails Attached Thumbnails IMG_2090_1024x768.jpg   IMG_2096_1024x768.jpg   IMG_2099_1024x768.jpg   IMG_2106_1024x768.jpg
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jul 2005
    969
    as always cant wait to see
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Hoss,
    I am glad to hear this is your next project as you know, this is the one I have been waiting for!!!!!!
    :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee: :wee:
    Bill
    Bill
    Hey Bill,
    Working on the face frame right now. It will mount to the PC cases and give
    me a frame to screw all the panels onto.
    That way, if I change my mind later it will be easy to replace or modify a switch layout.
    It will be 24 x 24 inches now. Plenty of room for doohickys and thingamabobs.
    I'm hoping to have all the framework and such done by next month
    so I can spend my vacation doing all the wiring. I'll make schematics this time.
    Later Hoss
    Attached Thumbnails Attached Thumbnails IMG_2111_1024x768.jpg   IMG_2117_1024x768.jpg
    Hoss,
    As "Gomer Pile" put it so eloquently,
    Thaaankya, Thaaankya, Thaaankya,
    I can't wait to see this take shape. I am dying to see how you integrate all the doohickys and thingamabobs. You must not forget all the bell's and whistles either. I am very curious on the MPG as I want to make the pendant with one also. I wonder how much of this will work with the HobbyCNC 4Pro kit I use.
    I am finished with the Tapping Tool and the ATC you have so graciously given us (many, many thanks).
    I am starting to CNC my Mini Lathe now while I wait to see what comes of this new project you have embarked on. I have all the material and am now getting around to drawing it up and tool pathing it up.
    One question though, well two;
    How are you adding all the goodies to your electronics and do you think I have to change over to something else other than the HobbyCNC driver to get it all to work. I'm wanting to be able to use some kind of a programmable controller to control the spindle, along with the pendant and tapper and the list goes onnnnnnnn!
    So many things to make and so little time, I'm just glad you are in the "Driver" seat (pun intended)!
    Thanks Again
    Bill
    Bill
    Hey Bill,
    Don't know much about the Hobbycnc board, you may need a breakout board for the extra inputs/outputs.
    One of the parts I'm adding is this 19 in. widescreen monitor from Dell.
    My eyes are going south, need the bigger screen.
    Hoss
    Finally got around to finishing the face frame.
    I'll make individual panels for the switches etc. that will mount onto this frame.
    Used some .190 x .750 6061 and riveted the half laps together.
    Now to mount the frame to the old PC cases.
    Later Hoss
    Attached Thumbnails Attached Thumbnails IMG_2249_1024x768.jpg   IMG_2253_1024x768.jpg   IMG_2256_1024x768.jpg
    A little more progress.
    Have the basic frame made, now to button it up with some sheet metal
    from the old PC cases and aluminum plate.
    In 2 weeks i'll start transferring the electronics from the old console.
    Hoss
    Attached Thumbnails Attached Thumbnails IMG_2316_1024x768.jpg   IMG_2321_1024x768.jpg   IMG_2326_1024x768.jpg
    Jul 2005
    969
    the art of taking a pinto and turning it into a corvette hey hoss what is going to be the footprint of your machine ounce you are done
    Hey ataxy,
    With the flood coolant enclosure, I'm taking up about 4 x 8 feet of workbench.
    The lathe will take up another half that too when it finally ships in April.
    Have to store some of the woodworking tools to make room.
    Guess I could move the hottub outside.
    Hoss
    Jul 2005
    969
    holy 4x8 wow big foot print
    Hoss,
    It looks like it's really coming along nicely. Starting to get me wondering if I want to make one also. Is that a mini keyboard from Sony for the Playstation? If so ... I have one already!
    I am hoping you document all that you are doing, I just might need that information from you! will you be adding a pendant also that plugs into the console?
    Keep on with your work!
    BTW ... you should plan on going to the WESTEC show out here in LA to get some really cool ideas.
    Bill
    Bill
    Hey Bill,
    It's a PS2 mini-keyboard from Dell.
    Probably no pendant since it will sit right next to the mill enclosure.
    Most of the switches will be on the left side.
    Gonna have some open panels on the right till I think of stuff to throw in there.
    Maybe a digital tach, coolant tank fluid level gage(have an old fuel tank gage and sender), etc.
    Hoss
    Picked up this trackball/mouse from Dell too.
    Now I won't need to add a shelf to use the regular mouse.
    Hoss
    Dec 2005
    141
    he hoss just a idea if you check dells server section you can find one of there compact server kb which have a touchpad mouse like a laptop
    kinda like this
    http://www.newegg.com/Product/Produc...82E16823166076
    the one from dell is smaller (size of laptop kb and then touch pad to left)
    i have one at work i will see if i can get a part number
    Mike
    Drat it all to heck,
    that would have been more convenient.
    I may just have to reconfigure for that.
    Thanks, :cheers:
    Hoss
    Hoss,
    I am not sure you want a touch pad for it. I use a laptop to run mine and I have to wipe my hands VERY WELL or the touch pad does not work very well.
    Just a thought ....
    Bill
    Bill
    Nov 2003
    244
    I believe the trackball is the better choice-I have one similar to this one
    http://www.newegg.com/Product/Produc...82E16823131087
    ...He who makes no mistakes makes nothing! ...
    Tom
    Dec 2005
    141
    hey hoss i was wrong itis a trackball on the kb i was talking about the p/n is 0292cx i have found a couple on the internet but they are kinda pricey. i bet you can find one on newegg for less
    mike
    Jul 2006
    122
    Idea on the keyboard.
    Would be neat if you could pull it down & out so you can use it easier.
    Maybe have it slide out if you have the room inside, then you could put a motor on it with a push button.
    Craze huh.
    Skip20
Page 1 of 5 123
  1. Hoss ATC Project
    By hoss2006 in forum Benchtop Machines
    Last Post: 04-06-2018, 07:56 AM
  2. Mill project
    By Jester966 in forum Vertical Mill, Lathe Project Log
    Last Post: 10-31-2015, 03:39 AM
  3. Hoss CNC Conversion material cost?
    By mrcodewiz in forum Benchtop Machines
    Last Post: 01-17-2008, 11:41 PM
  4. Show us your Console or Pendant!
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 01-14-2008, 07:06 PM
  5. Mach3 console?
    By RLC in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2006, 07:50 PM
