Just wondering what you should use to cut straight through an MDF board... What i'm intending on doing is cutting through a 9mm board, then using a bevel bit at around 45 degrees to get the finishing edge. I'm cutting through the board so i can have inlay mirrors in a wardrobe door. Do i use a straight through bit, or can somebody point me in the right direction where i could purchase the bit i need?
