586,119 active members*
3,587 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Cadet Graphing
    Jan 2008
    Smile Okuma Cadet Graphing
    We have a Okuma Cadet turning center with a 5240 control on it.
    I can not get the graph to put the material in the graph.
    I was told to try putting
    Clear
    def Work
    PS LC,[0,0],[1.25,2.0]
    END
    DRAW
    In the beginning of my program and I would get a bar showing up in the
    graph screen with a size of 1.25 dia by 2 inches long . This did not work.
    Is there some where else to define the material stock on the control.
    Is there a parameter I need to set???
    Any help here
    Jan 2008
    5
    Not sure about the 5240 control.
    Here's how I do it on my 5000L-G and 5020L controls. Length is first then diameter. For 2 inch long part by 1.25 inch diameter it would look like this:
    DEF WORK
    PS LC,[0,0],[20,12]
    END
    DRAW
    Notice no decimals in the brackets. I don't know if the 5240 control works with decimals. Obviously the 12 isn't exact for 1.25 inch...it's up to you to use either 12 or 13 (1.2 or 1.3 inch).
    Jan 2008
    Smile Thanks
    Worked !!! Decimals seemed to be the problem.
    Thanks Ron
  1. Graphing software
    By atmosports in forum Uncategorised CAM Discussion
    Last Post: 09-01-2010, 05:31 AM
  2. Okuma Cadet-Mate RS232/Serial port use?
    By brujo in forum Okuma
    Last Post: 06-21-2007, 01:35 PM
  3. 1999 Okuma cadet mate
    By NCcustom in forum DNC Problems and Solutions
    Last Post: 03-23-2007, 12:43 AM
  4. okuma cadet lathe osp 5020l
    By bryanpackmac in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-26-2007, 01:36 AM
  5. Any free G-Code graphing software?
    By bdrmachine in forum G-Code Programing
    Last Post: 09-13-2004, 04:57 PM
