586,060 active members*
4,275 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Learning about CNC lathes
    Apr 2006
    19
    Does a CNC lathe require a C axis to do threading or can a basic 2 axis machine somehow sync the Z to the spindle to do threading?
    Robert Newbie
    Apr 2006
    19
    Maybe a better question would be - do all 2 axis turning centers have an encoder on the spindle for sync to Z and threading? Does having a C axis imply that the spindle rotation is under servo control and can be stopped at any position?
    Robert
    Jan 2007
    355
    Any decent 2 axis turning center will be capable of threadcutting.
    A turning center with a 'C' axis ( rotation about the 'Z' axis ) is able to precisely position the chuck. Add live tooling, and the lathe can perform many of the operations that a machining center does (mill, drill, tap, etc.) .
  1. Learning...Need help with PSU
    By h3ndrix in forum CNC Machine Related Electronics
    Last Post: 02-24-2007, 11:38 PM
  2. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
  3. Lathes, what’s the difference between the different types of lathes out there?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 03-15-2006, 09:07 AM
  4. learning
    By massbaster in forum Uncategorised MetalWorking Machines
    Last Post: 05-04-2005, 09:25 PM
