586,379 active members*
3,485 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Cutting Acrylic on a Wood Router
Page 1 of 2 12
Results 1 to 20 of 25
    Dec 2006
    11
    I tried my hand at cutting 3/16" plexiglass last night. I got a porter cable 10 amp router that spins up at 23K or 28K RPM. I used a 10 IPM feed, and 1/4" 2 flute spiral up cut bit.
    The material appears to have melted more than cut. I had to use a chisel to get it off the table! After some handy work with a utility knife, I got to a clean enough edge, but there's got to be a better way to work this stuff.
    Does anyone have any suggestions, bits, feeds, speeds?
    Dean Brock
    Jun 2004
    6618
    Plastic cutting bits are usually straight cutters. No up or down cut. They don't do much rubbing this way. I use 3/16" 2 flute straight cutters made by Onsrud. I cut lexan, which has a higher melting temp. I cut with a feedrate of 80 IPM for tight arcs and 150 for everything else.
    I think with a slow feedrate like you were using, you are componding the heat issue.
    Speed it up if you can. Multiple passes might help too. If you can't speed it up on feed, then slowing the router might help some too. I use a cheap router speed controller on my PC 690 when I need to slow it down.
    The torque falls off with the speed, but then if I make a couple passes, it works great.
    Lee
    Slow your rpm down to 23K, and up your feedrate to about 100ipm. With a 1/4" tool, you'll probably still have trouble due to the chips packing in the cut, unless you can blow compressed air on them to clear them out. You're best bet would probably be to try to rough cut them about 1/32" oversize, remove the surrounding scrap and then run a finishing pass.
    Nov 2005
    1468
    Conventional cutting (vs climb cutting) helps too- the chips don't get stuck to each other. I'm milling the stuff at 2.4K rpm (WAY below you) and about 11ipm with an 18mm end mill. Rack the RPM down until you get a steady stream of individual chips coming off the cut then increase it while catching the chips in your hand- you will be able to tell when the chips are getting too hot and this is your optimal cutting speed/ feed. If they come off all gnarly and stuck together you're going too fast.
    I know I'm using a mil and you're using a router, but the main reason cutting acrylic or other polymers fail is the spindle being too fast... it melts (and smells lol).
    2 flutes are better than 3 or 4 which whak the material too much
    I love deadlines- I like the whooshing sound they make as they fly by.
    Feb 2006
    210
    I engrave plexi plates(with v bit) for foundry match plates and end up sitting there with a stick constantly knocking the little blob of plastic off the end of the bit. If not the blob just gets bigger and ruins the letters( usually 1/8 to 1/4 high)
    Dave
    In the words of the Toolman--If you didn't make it yourself, it's not really yours!
    Remember- done beats perfect every time!!
    Aug 2006
    65
    I know it's a router, I have a 2 1/4 hp PC on my K2cnc and manufacture a box out of 1.00 cast sheet and I cut .750 deep and I [ food grade mineral oil ] in a squirt bottle, light spray, or silicone spray non flamable. works for me. And if you have a dust exracter, it's even better as to keep it out of your router. and if you not going very deep you can use wax.
    9lrac9
    Quote Originally Posted by beone View Post
    Dave
    Try using liquid Dish-Soap mixed with a little water, it washes off easy, and the plastic will never stick to the tool!
    It also makes the finished part more transparent, instead of dull frosted look.
    The nice thin is you don't need a lot, just paint the area prior to machining!
    Widgit
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    Jun 2004
    6618
    Quote Originally Posted by widgitmaster View Post
    Widgit
    The downside is it leaves a few clean spots in the shop so the really dirty spots stand out more.
    Lee
    Feb 2006
    210
    Widgit
    I will give this a try
    Dave
    Feb 2006
    210
    Widgetmaster, You rock!! It never ceases to amaze me how the little things make all the difference. Cut a plexi plate last night and used the soap-- came out beautiful.
    Thanks a million!
    Dave
    If you want to cut plex and have it come out crystal clear like a window use Kerosine for the cutting fluid. An old trick I learned at a Plastics Machine Shop years ago. You will be amazed by the results.
    mgranato Guest
    I've got some 3/8" cast acrylic to cut with the paper backing, when you guys are talking about the soap/kerosine, are you removing the paper first before cutting or leaving it on? I've just got my CNC, so anything more detailed about this method would be a big help.
    Jun 2004
    6618
    I leave the protective backing on when I can. If you are just cutting the edges or a profile, I don't think it will hurt anything.
    I get lexan sometimes with paper backing rather than the normal plastic. It holds much better while milling or routing.
    Less chance for chips to scratch the surface.
    I have heard about soap before, but never actually tried it. I might have to to see if it makes a difference in lexan.
    Lee
    kerosine may make the paper mushy but....
    keep the paper to protect it from scratches. you will be amazed how clear the plex will be.
    Jul 2005
    12177
    Quote Originally Posted by Mike Stevenson View Post
    If you go back to the first post it says: " I got a porter cable 10 amp router that.....". This router, like most routers, is a universal motor (I think that is the correct name), a motor with a commutator...that makes sparks...you can see them when the motor is running. Kerosene is flammable, and when heated vaporizes. You could be quite thoroughly amazed if you managed to heat things up enough to create kerosene vapors that got sucked in by the cooling fan on the router and ignited by the sparks in the commutator.
    Use soap like Mr Widgit recommends; I have never heard of soap vapors causing an explosion.
    Soap is fine but the finish will be frosted not clear. Working with a sparking router that can cause a fire is not safe under ANY circumstances.
    Jul 2005
    12177
    The finish is frosted no matter what you use as a lubricant, once you have washed all traces of the lubricant off. And if you are going to avoid working with a router that has a universal motor because the commutator sparks you will never use it; it is impossible to run a commutator motor without some sparking.
    No you're wrong. If you use Kerosine it comes out chrystal clear like the rest of the material. If you haven't tried it you don't know.
    Jun 2004
    6618
    I have to say I would be leary of using any type of solvent or fuel or oil on plastics. I have experimented with some and it becomes unclear and clear why I shouldn't have done that.
    Most of the cuts I make on lexan are then welded with solvent later. They clear up some just from that. Upon second thinking, a lube would be yet another set I would have to wash off.
    A torch also works well to clear the edges. They have to be pretty smooth to begin with, but flame licking the edge will make it clear and shine. It like most thing, takes practice to get good at it.
    Too much flame will be self evident.
    Lee
Page 1 of 2 12
  1. Cutting Acrylic
    By Gujustud in forum Glass, Plastic and Stone
    Last Post: 01-28-2009, 02:05 AM
  2. Cutting 2" cast acrylic
    By routski in forum Material Machining Solutions
    Last Post: 01-11-2008, 09:44 AM
  3. Cutting PETG and acrylic Questions
    By FlyGuy007 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-15-2007, 02:18 PM
  4. laser cutting acrylic - art application
    By charper in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2006, 07:50 AM
