586,058 active members*
3,437 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > NEED HEELP ALARM #414 Y AXIS SERVO ALARM?
Results 1 to 7 of 7
    Aug 2005
    57
    Unhappy NEED HEELP ALARM #414 Y AXIS SERVO ALARM?
    HELLO ALL,
    I KEEP GETTING THIS ALARM ON MY FANUC 18 CONTROL, AND CANT FIGURE OUT WHY. I MAINLY GET IT WHEN I USE THE MPG AT FULL SPEED OR IF I TURN MY RAPID UP OVER 50%. I HAVE TAKEN OFF THE SERVO AND MOVED THE MPG HANDLE AROUND AND NO ALARM. I ALSO MOVED THE Y AXIS WIRES AROUND THINKING IT WAS A SHORT. IM LOST AND CONFUSED! PLEASE HELP!
    THANKS,
    PICMAN
    24221
    This is a Digital servo alarm, what number is on the servo amp? or look in diagnostic 200 the bit will tell you what the cause of the error is.
    Al.
    Albert E.
    Feb 2007
    464
    The Y axis isn't running as smooth as it should.I got this alarm a couple off times on the Z axis before I found out what it was.The ways were dry.No lubrication.'
    Or it could be a bad servo/motor.
    Stefan Vendin
    Apr 2011
    if the alarm exist.pls. check diagnostic parameter 200 and check the diagnostic status
    Apr 2011
    check the diagnostic parameter 200 bit 2,3,if the bit is 1 the servo is HVA or HVO.meaning the axis is stock up or the teflon slide is damage.
    Feb 2011
    640
    is it a horizontal mill? be sure if its a gravity axis that the brake is releasing and the counterbalance is set right.
    you should have a servo tuning page- system, right shift, servo(setting?),servo (tuning?)...forget what the key says- anyway it will show current% if current excessive only in one direction, could be a thrust bearing/ballnut (or counterbalance of course if gravity axis). high current both ways= lube like someone already mentioned, slide damage, screw/bearing/brake trouble.
    if servo current is NOT excessive, your 'linear acc/dec for manual feed' parameter might be too short...most machines run around 100msec or more to keep the MPG from making the servo growl too bad from pulsed movement...
    Jan 2009
    117
    Maybe try to swop out the motors.
    Check parameter 2020 X and Y. If, and only if these values are the same you can do the following:
    1.Swap the JF1 and JF2 cables on the servo amp. This is for a dual servo amp.
    2. Interchange the U,V,W wires (keeping the same order) between the L and M terminals for the power cables.
    3. Power On and use the X-axis command to move the Y-axis motor and vice versa.
    If the problem moves to the X-axis motor, the fault is not cabling or motors.
    Next:
    1. Interchange JV1 or JS1 with JV2 or JS2 cables on the servo amp.
    2. Power On and check movement / alarms. (X command will move X-axis this time etc.)
    If the alarm / problem persists on the Y-axis:
    1. Parameter adjustment / correction required.
    2. Main PCB or axes control module might be faulty.
    3. Servo amp and motor are probably ok. Amp is faulty if X-axis motor starts with symptoms / alarm.
    (Remember to return cables to original positions after this test)
    Also:
    Backup the parameters first then initialize the Y-axis parameters:
    Set PRM2000 Y to 00000000.
    Manually type the parameters for Y from 2002 up to 2024.
    Power off then on and check.
    Reload original parameters if no improvement detected.
    The above assumes FS-18MA/B/C. The first test will work also for FS-18iMA/B as well as the parameter initialize test, provided that servo tuning was not performed to eliminate problems associated with vibration etc.
    Confusing again hehe but quite effective. Let us know which FS-18 you have, the servo amp spec and value of PRM 2020...
  1. Fanuc Om-417 X Axis Servo Alarm
    By intermax in forum Fanuc
    Last Post: 05-11-2022, 11:55 AM
  2. Y-axis servo alarm #329
    By MIYANO vs FANUC in forum Fanuc
    Last Post: 04-18-2022, 03:49 PM
  3. 434 servo alarm: Z axis detect error
    By padobranac in forum Fanuc
    Last Post: 12-21-2021, 03:18 PM
  4. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  5. Fanuc 18I Z axis servo Alarm 410
    By Ninus in forum Fanuc
    Last Post: 09-22-2006, 05:16 AM
