586,076 active members*
3,874 visitors online*
Results 1 to 8 of 8
    Nov 2003
    459
    Flood coolant on steroids
    I wonder if anyone has researched installing: "Through the tool coolant" on your CNC machine?
    I'd like to know what the design considerations are?
    What are some options for the rotating seal component?
    Pressure limits?
    Drawbar modifications?
    I think I'll break out the CNC machine schematics...
    Fadal VMC with 15k spindle. Fadal does not offer this as an option for their 15k machine, only their 10k spindle. Their seal does not work that well so no wonder it does not work for them on the 15k...
    Other CNC builders and high pressure coolant systems do make high RPM units.
    I wonder...
    Scott_bob
    May 2004
    83
    To be worthwhile, thru tool coolant needs to have several hundred psi available to be able to blast chips out of holes, etc where the chips cause the most problems. Gets out of the range of your basic high clearance centrifugal pump rather quickly. The tight pump clearances require filtering similar to what's necessary in high end surface or cylindrical grinding, otherwise the fines will destroy the pump in short order. Obviously a totally enclosed machine is necessary. When you look at the upfront costs of TTC, including the sealed collets that are 2 to 3 times the cost of standard collets, and the associated maintenance costs of the system itself, the whole system seems to be a thing that would be considerable only if the buyer has a well defined need for it.
    I read something several months ago about a gun-drilling system that forces coolant down the periphery of the drill and evacuates chips back up the center of the hollow tool. I can imagine that would be a rather complicated process, to say the least
    Nov 2003
    459
    Here is the new coolant manifold we fabricated:
    This works fine with the stock 40 psi pump that came with the machine.
    It works much better with the new 150 psi pump we have on the machine now.
    This design surrounds the tool as much as possible as you can see.
    These high pressure nozzles cannot be moved by stringy chips so they stay put...
    Scott_bob
    Nov 2003
    459
    next image
    Scott_bob
    Nov 2003
    459
    next...
    Scott_bob
    Apr 2004
    88
    http://www.deublin.net/index.htm Scott have you looked at the rotary couplings from deublin
    they have several for coolant through spindle aplications.
    Mar 2004
    41
    if you only want through tool coolant far applications like deep drilling you should look at KBC tools they have both tools and tool holders that just use inducer collars and look like you could use them with any pump that will give you some reasonable presure
    Apr 2005
    1194
    I love that splash guard!
  1. Coolant eating my paint.
    By nervis1 in forum Uncategorised MetalWorking Machines
    Last Post: 12-05-2007, 10:27 PM
  2. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
  3. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
  4. good flood coolant found.
    By nervis1 in forum MetalWork Discussion
    Last Post: 12-23-2004, 11:16 PM
  5. Question about applying coolant
    By HawainPand in forum MetalWork Discussion
    Last Post: 10-17-2004, 04:02 AM
