586,106 active members*
3,106 visitors online*
    May 2007
    163
    Small shop 3 machines
    Ok guys this question is a bit odd but I need your input.
    My Tormach, 9x49 Enco knee mill and 14x40 lathe is
    in a fairly big shop that is not climate controlled so
    when the humidity goes up ever thing sweets’ bad.
    I’m constaly spraying my machines with WD40 to keep them from rusting.
    So I built a 18x20 shop that’s insulated and climate
    controlled.
    My question is should I put my machines with there backs to the wall and have a bench in the middle of
    the shop or should put there backs facing the middle
    and a bench on the wall?
    Chris
    Jun 2004
    6618
    All three of my machines are up against a wall. They are small machines though. I have a router that is about 3' by 4' stuck in the corner. Then I have a small mill in the middle. Then a 7/12 lathe and at the end of that is my bench longways into the corner.
    It's only a 16' wall.
    One of the woodworking sites has a shop layout thingy that might help you with this. I move tools around all the time in the shop, but those were woodworking tools and on wheels. While I have wheels on the lathe and the router, I have them sitting on timbers now. Pretty solid like that.
    Ah. I found it.
    It was Grizzly.
    http://grizzlyindustrial.com/workshopplanner.aspx
    Lee
    May 2007
    163
    Man Thanks so much!!!! I wish I could buy you a beer!!!
    That Grizzly shop layout tool is so cool!!!!
    Part of my shop layout
    Hey, TT350...for your shop, it's anything that floats your boat.
    Here's part of my layout. This is the east building in our little "compound". Until very recently (2 weeks ago), our toolroom was restricted to the room in the lower left. However, we got our new Tormach (WooHoo!) and the lathe got bumped up to the small molding area at the upper left. The area towards the center top is the product development lab (mostly electronics). At the upper right is our engineering area. The big room at the lower center and right is for woodworking, restoring and storing antique tractors and general garage stuff. I hope to fill that with more cnc's and boot the woodworking/tractors/garage out to a third building.
    More to your point, I've always preferred the machines around the outside and workbenches in the center for a machine area.
    Have fun designing your shop.
    Feb 2008
    180
    Behind the machine is a bad idea.
  1. What machines are in your home hobby shop?
    By widgitmaster in forum Polls
    Last Post: 12-13-2019, 07:39 PM
  2. Info on Bridgeport Torq Cut 22 w/ DX 32 or other small machines??
    By vettespeed in forum Knee Vertical Mills
    Last Post: 10-04-2010, 11:19 PM
  3. 4X4 Small Shop log
    By Trail Logic in forum Torchmate
    Last Post: 03-24-2008, 03:35 PM
  4. Realistic expectations of small CNC machines?
    By Sammas in forum Benchtop Machines
    Last Post: 06-22-2006, 09:35 PM
  5. Would like to open small shop.
    By speed33317 in forum Haas Mills
    Last Post: 06-30-2005, 03:05 PM
