586,103 active members*
3,719 visitors online*
Results 1 to 1 of 1
    May 2007
    102
    Inhibit vs phase chopping
    Could somone explain the adavantages and disadvantages of these two
    chopping methods .
    Also calles fast vs slow decay if I understand correctly .
    The story behind this question .
    I'm building , or maybe better I'm trying to build , a 1/4 step driver .
    Using a L6506 current controller , a 1 bit DAC , and the well known L298
    as a driver . A gal 22V12 will produce the necessary logic .
    I kow there are chips out there that will do the job , I just like to design something myself . And using a gal has several other advantages like e-stop and synchronised limitswitches
    The problem is that wathever I do , the L6506 goes out of control , and the phase current drops to nearly zero as the voltage is increased beyond .
    the maximum allowed stepper voltage .
    So I've read that fast decay offers a better current control wich might solve my problem , but also produces a larger ripple .
    Secondly , I've seen on some datasheets that an RC chain is put across each stepper winding . Is this a substitute for the clamping diodes , or do they have a different function .
    Thx
    Patrick
    Picture shows a not yet finished prototype .
    The basic idea is to use standoffs to mount the pcb on the back of a nema23
  1. DIY Driver, LMV339 chopper, 74HC08 not chopping.
    By vim.au in forum CNC Machine Related Electronics
    Last Post: 02-08-2008, 10:32 AM
  2. Relations between chopping frequency and step pulse rate
    By bunalmis in forum Stepper Motors / Drives
    Last Post: 05-30-2006, 05:37 PM
  3. Cutting/Chopping small aluminum pc's best way?
    By dbtoutfit in forum MetalWork Discussion
    Last Post: 03-19-2006, 01:28 AM
  4. phase chopping l297+l298
    By dfv in forum CNC Machine Related Electronics
    Last Post: 06-17-2005, 01:33 AM
  5. Quesion regarding inhibit jumper settings for Fanuc drive
    By cncboy in forum CamSoft Products
    Last Post: 03-08-2005, 12:43 AM
