586,104 active members*
3,403 visitors online*
Results 1 to 12 of 12
    Sep 2005
    46
    TL2 Beeps for no reason
    Hi Geoff, its been a while a question for lathe owners my TL2 with about 500hrs on it has two issues, first is that the spindle shuts down as soon as the spindle fan cuts in ...so I disconected the spindle fan ..and am about to pull the fan out and have it rebuilt..
    The other is that the contoler beeps for no reason nothing happens just beeps every 10 secs or so sometimes double beep any Ideas anyone it drives me nuts yes I could disconect it but would rather not at this stage cheers Peter
    Nov 2007
    1702
    Hmmm...I'm curious what you find out. My 2004 VF-2 does exactly the same thing. I've looked at incoming as well as DC power with an oscilloscope. Nothing coincides with the beeping. It's just random and usually happens right after power up.
    Now that I think about it: the machine has been running regularly for the past few days and it hasn't been doing it.
    Greg
    Jul 2005
    12177
    The prodigal biker returns. Well over a year, you must have been having fun.
    Can't help with beeps or finicky fan motor; so far neither of these have showed up on my machine.
    Apr 2007
    178
    could be one of the buttons on the keypad if it has the rubber lifted buttons when they first came out they were very sensitive. you can disconnect the keypad and see if it goes away. the only other thing i can think of is the m fin signal if there is anything connected to it and is flaky it beeps when you close the m fin.
    REYTECH Machine Service Corp. CNC repair NY, NJ
    http://www.reytechmachine.com
    Sep 2005
    46
    Hi Guys , Serviceman whats the m fin and what could be conected to it ...Im a novice you see
    Geoff yes having lots of fun with the three wheeler still not finished but nearly Im up to the wiring at the momment and struggling to make it really neat....Ill get there worst part is the Old back is giving trouble couple that with a leaky brain and its not a good combination Peter
    Nov 2007
    1702
    Quote Originally Posted by serviceman View Post
    I thought that too but nothing appears on the screen, no characters, no mode changes, nothing. The control will just randomly beep. It's not a regular beeping either. It'll blip three or four times, be quiet for awhile, then one or two, then quiet, then more blips.
    Would you still suspect the keypad?
    Peter: does my description above kinda' represent what yours is doing? What year is your TL-2? I wonder if we have the same keypad.
    Greg
    Sep 2005
    46
    Yes that about decribes it to a Tee, cheers Peter
    Jul 2005
    12177
    Have either of you taken the back off the control and checked that the connectors to the keyboard are all tight? I had a problem with the jog wheel intermittently not working and this was resolved by unplugging all the connectors and then re-connecting them.
    Nov 2007
    1702
    I have never seen inside the control pendant. Mebbe' it's time to have a looksee.
    Fortunately, I've been busy running both machines for the past few days. They're both warming up right now. Diagnostics will have to wait a few more days.
    Greg
    Sep 2005
    46
    Well I did as you suggested Geoff I took the back off the control pendant and pushed and poked all the terminals, I guess that the red and black wires from the circut board to the beeper could have been considered loose so anyway fiddled with it and put the cover on fired it up and played with EVERY button left it for half an hour and all seems to be ok thus far Ill keep you posted cheers Peter
    Sep 2005
    46
    Talking
    Hey all well I used the lathe for a couple of hours the other day, well perhaps I used it for 30 mins but it was switch on for a couple of hours and NO beeps so Geoff it seems you were right thank mate take care Cheers Peter
    Nov 2007
    1702
    I'm embarrassed to admit this, but mine has been fine since I actually started using it again.
    It sat, doing nothing for two years. I've added 10 'in cut' hours to it in the past 5 days. That's pretty good considering that's 25% of it's total cutting time.
    I guess they don't like being left off. :withstupi
    Greg
  1. Machine beeps, then freezes
    By dapoopta in forum Haas Mills
    Last Post: 02-18-2024, 09:35 PM
  2. Reason for Y-axis limitations
    By tikka308 in forum Benchtop Machines
    Last Post: 07-31-2007, 11:44 PM
  3. Can any servo motor be run from any driver? (within reason)
    By Darc in forum Servo Motors / Drives
    Last Post: 05-31-2005, 09:53 PM
  4. I want one and now I have a reason.
    By rustranch in forum DIY CNC Router Table Machines
    Last Post: 10-10-2003, 04:58 AM
  5. CNC for what reason?
    By WallCrawler in forum Community Club House
    Last Post: 06-17-2003, 05:30 PM
