586,913 active members*
2,920 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Can G320 drive 2 motors in series?
    Jan 2007
    64
    Is it OK for me to connect two motors to a single G320? I have 2 motors driving a single axis, with a single encoder. I'm using 2 as it was a simple way to get more torque, given that I have plenty of identical motors.
    Would it be best to connect them in series or parallel?
    They are about 40 inches apart.. so the G320 can't be close to both of them. Should I just put it halfway between them? Or should I put it close to the one that has the encoder?
    (These motors are not huge, and the G320 can easily supply enough current & voltage if I put them in series).
    Neil
    Jul 2004
    601
    No. You need 2 drives.
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    Aug 2004
    3215
    Quote Originally Posted by DSL PWR View Post
    I have driven two motors from one G201 drive, not sure about G320's.
    Joe
    Jan 2007
    64
    Can you say why?
    Neil
    Nov 2005
    256
    If the combined armature voltage of the motors is less than or equal to the available voltage from the G320, it should work fine. This assumes that the motors are driving a common thread/shaft/pinion whatever. This is done with large motors at times, especially in days gone by. The advantage of series connecting the motors is that both have to share the load equally. It won't matter on lead length of one versus the other either. Two motors tied in parallel may share the load equally, but only if the motors are very closely matched and lead length differences could be an issue. The parallel connection is often seen in conjunction with shunt field motors having a means to vary the field current in one motor so the current is shared equally.
    If the two shafts are not rigidly tied to each other or through the load, it may or may not work well. Most likely not.
  1. Magmotor C40 series which is best match for G320 ?
    By Paraprop in forum Gecko Drives
    Last Post: 04-14-2007, 05:01 PM
  2. Replies: 2
    Last Post: 04-10-2007, 03:45 AM
  3. VFD drive Faults on series I cnc Bridgeport
    By colin1544 in forum Bridgeport / Hardinge Mills
    Last Post: 09-22-2006, 11:36 PM
  4. can brushless drive drive brushed motors ?
    By max_imum2000 in forum Servo Motors / Drives
    Last Post: 02-09-2006, 02:35 PM
  5. Stepper motors in series?
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2005, 09:10 PM
