586,106 active members*
2,987 visitors online*
    Feb 2008
    13
    Mazak Multiplex 6200
    Hey guys, just found this site and it looks like there are some very insightful people here.
    We just got a new Multiplex (our first one). I program using Mazatrol and for whatever reason I cannot use a manual program for head 2. The numbers on Z are way off. For example, I tell a drill to go to X and Z zero, the drill stops 4" in front of the part. I have managed so far just using all Mazatrol for head two but we all know there are some times where a manual program is much faster. I am talking about a Manual program, not EIA. Any help would be appreciated.
    Feb 2008
    Keep in mind on the Head 2 side all z point must come from original Z0. Z0 should have crashed your machine. I am thinking it should have anyway. We have 6 Multiplexes in our shop. We use mazatrol for most everything. Rarely do we use Manual program. So I can't help much.
    Feb 2008
    13
    correct
    That is correct. The part is 4" long and it still came down way in front of the part. I tried 0.00, 4.000 and -4.000 and it never came anywhere near the face of the part.
    Feb 2006
    992
    Check you common XYZ program zero point/offset zero point, you might have fish munber somewhere right there.
    The best way to learn is trial error.
  1. MAZAK MULTIPLEX PROGRAMMER AND SETUP MAN
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-15-2008, 07:19 PM
  2. MULTIPLEX 420 Alarms
    By CIMMaster in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-06-2007, 09:19 PM
  3. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  4. Mazak M plus and FDD
    By nicolabucci in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-13-2006, 03:01 PM
  5. looking for an old kolemorgan 6200
    By boomer187um in forum CNC Machine Related Electronics
    Last Post: 08-28-2005, 10:51 PM
