I was looking to get dc servo brush motors 1000-oz-in ...but then i came across this ....need help converting units
seen a motor with lbs-in units,,,, dont know if it strong enough...and
how does this compair to a motor that just say 1000-oz-in peak torq.?
ID33000 series NEMA 34 brush DC motors
http://www.motioncontrolgroup.com/pr...formance-specs
RATINGS Symbol Units
Units
Continuous Stall Torque Tcs 1.198 Nm 10.60 lb-in
Peak Stall Torque Tps 6.000 Nm 53.10 lb-in
No Load Max. Speed ω nl 6000 RPM 6000 RPM
Continuous Rated Torque Tcr 0.805 Nm 7.12 lb-in
Peak Rated Torque Tpr 1.610 Nm 14.25 lb-in
Rated Speed ω rated 4400 RPM 4400 RPM
Rated Power W 371 watts 371 watts
Rated Power Hp 0.50 Hp 0.50 Hp
Inductance, L-L L 2.35 mH 2.35 mH
Resistance, L-L R 0.69 ohms 0.69 ohms
Max. Terminal Voltage V dc 90 Vdc 90 Vdc
