586,116 active members*
3,360 visitors online*
Thread: Oil Grooves
    Jan 2007
    10
    Oil Grooves
    I would greatly apreciate if someon out there can help me with progamming some oil grooves on the I.d. and face of a steel bushing. The grooves are mirrored one is left hand and the other is right hand and the face groove starts in the same place one of the i.d grooves starts. I have 3 different makes of CNC lathes Mazak Quick turn with 640T nexus control, Mori Seiki SL250 with Fanuc MSC518TC controls and Deawoo Puma with Fanuc 21I-TB controls. If anyone Knows anything that can help me I would greatly apreciate it. Attachment in PDF format Please Help.
    Attached Files Attached Files
    Feb 2008
    24
    are you planning on using g32?
    Jan 2007
    10
    Oil Grooves
    I intend to try using the threading cycle. But what I am not sure of is how I'm going to do the mirrored groove at 180 degrees.
    Feb 2008
    24
    simple solution for the second pass, reverse the spindle, do the same pass, start exactly 1/2 lead further away from the part than on the first pass . most of the time double lead threads are done that way (some mahcines allow phasing in threading and the start point need not be altered)
    Feb 2008
    9
    Your Mazak will allow "phasing" of a thread cycle. In the THD process
    it asks how many entry's, under MULTI for a 180° rotation that obviously would be 2.
  1. Whats the best way to get these grooves..
    By kprice1658 in forum Rhino 3D
    Last Post: 08-17-2007, 09:26 AM
  2. Grooves MCX
    By jorgehrr in forum Mastercam
    Last Post: 04-18-2007, 09:58 PM
  3. How do you cut wide grooves with a small bit?
    By randyf1965 in forum DIY CNC Router Table Machines
    Last Post: 04-27-2006, 02:09 AM
  4. Machining grooves
    By itsme in forum MetalWork Discussion
    Last Post: 10-03-2005, 07:07 PM
  5. Replies: 1
    Last Post: 11-12-2004, 05:28 PM
