586,114 active members*
3,283 visitors online*
Results 1 to 8 of 8
    Apr 2006
    19
    Question Tool Nose Radius
    We just got a HAAS TL-4 Lathe. I have been doing the programming for our Mills for about five years now, but this is the first lathe I will have programmed. At this point my main concern is how to use the tool nose radius compensation. I would like to have the Program do all the compensating for the radius on the tool just as with programming using centerline programming on the mills(no need to but a tool diameter or radius in). I use FeatureCam for most of my programming but I also have MasterCam and SurfCam. I can see many obsticles because of it being a toolroom lathe but I will start with this one.
    Speeeeeeeeeeeeeeed
    Feb 2006
    992
    Everyone has their own way to do thing, but I found programming on the lathe the easiest is program with 0radius, then put tool radius and direction in the offset and machine will take care the rest. I knew you working with milling for so long and found it diffcult the new idea. Machinist end up stuck with same tool/let say it create chatter........ end up rewrite program.
    The best way to learn is trial error.
    Jul 2005
    181
    Config your featurecam so it will program it. Mine was doing it but I prefer to make the control do the job in a canned cycle. After if I have a similar part but different dimmension, I just have to change the profile wants and don't botther with the tool comp. But hey, all roads leads to Rome!
    Feb 2008
    40
    I dont know that software and I know it sucks to manually edit your posts but if you put a G42 for O.D. and a G41 for I.D. in a canned cycle the machine will do all the math for you.
    Nov 2007
    1702
    Quote Originally Posted by littlerobb View Post
    ... but if you put a G42 for O.D. and a G41 for I.D. in a canned cycle...
    Careful with that thinking. "G42 for OD" got me in trouble with a part recently and it drove me nuts with TNC. G42 is for 'Tool Right' compensation. I was turning toward the tailstock and the TNC was going backward. I couldn't figure out what the heck I was doing wrong. It was supposed to be G41 (tool left) even though it was the outside of the part.
    Don't make the same mistake. I scrapped a lot of brass that day. :withstupi
    Greg
    Feb 2008
    40
    tool right tool left
    That is true thanks for the tip I would have done the same thing and been scratching my head
    Jan 2007
    243
    Simple Lathe Cam
    try this program for calculating the compensations on your lathe: WebMachinist.Net The Online Source for Machining Resources
    Jan 2007
    243
    Re: Tool Nose Radius
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
  1. Tool nose radius compensation on SL-3a
    By cheenky in forum Mori Seiki lathes
    Last Post: 12-10-2012, 08:49 PM
  2. Tool Nose Radius Comp
    By lukehonor in forum G-Code Programing
    Last Post: 12-27-2010, 11:22 PM
  3. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  4. Help with tool nose radius comp
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-09-2008, 02:25 PM
  5. G42 Tool nose radius.
    By al-108 in forum Okuma
    Last Post: 03-02-2008, 08:39 AM
