586,108 active members*
3,208 visitors online*
IndustryArena Forum > CAM Software > Vectric > Cut3D- Machining of Romanesque Style Column using SLICE FUNCTION
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    Apr 2006
    3498
    Dear Tony Mac
    some details are missing as you can compare in the pictures but i think this may be due to low grade of MDF or humidity that made the slices details chipped off....
    By the way my experimentation so for going good...
  2. #22
    Those details are undercuts. You'd need to cut that from the side, not the top in order to cut those details. But you'll probably still have issues. Your best bet would be a rotary axis, but here's what you might want to try. Rotate the model on it's side, then rotate it 45° so the corner is the top. Then only cut half the model, but cut it twice and put the two halfs together. That will probably give you the best chance at getting most of the detail.
    Unless Tony has a better idea.
  3. #23
    Apr 2006
    3498
    Ohhh.. something is missing
    In the morning i entered into the Machine Room..and i saw the blank from where i machined the slices, ohhhh...one slice (The Top one) remain embeded in the blank...
    So that was the reason i was feeling something very odd in the machined model..
    You see in above pictures , i have shown only 07 pieces and in one of the Vcarve Pro simulation there are 8 slices....
    Now the columns is completed looks much better then previous one...
  4. #24
    Apr 2006
    3498
    Thank you Ger21 for explaination, Now let us suppose we have to make it on its original size (i.e. not a scale model), In this condition we will require a big routery axis.... or some other method to handle that big part.
    Moreover, i am very sorry i didnt understand the technique (the one with 45 degree) you mentioned above. I will be gratful if you can provide a little more explaination on it. If you require the COLUMN BASE model i can upload it for you.
    Again Thanks for your professional suggestions...
    Best Regards
    KFK
  5. #25
    Apr 2006
    3498
    In physical world, let slice a Carrot. we will get no undercut (Each slice is independent of other)...Just take the case of AUTOCAD,if we manually slice the model then it will take time but missing no details, If the same technique is implemented in this software then this will make the CUT3D unbeatable
    Again, The machining toolpath generated by CUT3D for slices is wonderful and great...
    I think my message will make some sense..although it is in very bad english....
  6. #26
    Apr 2006
    3498
    I wish i would have a forest around my home....
    '''''''''''''''''''''''''''''OOPPPPPSssss
  7. #27
    Quote Originally Posted by Khalid View Post
    Best Regards
    KFK
    Rotate it to this position before slicing may give you more detail on the sides. Although thinking about it, you'll still lose some detail. I think a rotary axis would work best, but I don't think Cut3D supports rotary axis, do they?
  8. #28
    Apr 2006
    3498
    Nope..No rotary support...
    thanks again for making drawing and explaining...I will check in CUT3D but there i think no rotate function (only 90 Degree rotation) ( i dont remember..customised rotate function)...
    Again, I thought and understand that AutoCad can't do the slices as CUT3D do for such type of maching work...
  9. #29
    Apr 2006
    3498
    Off the topic from Subject thread.........
  10. #30
    Apr 2005
    3634
    Another option, would be to turn the model on it's side in Cut3D, take a slice of a single side (the image you posted, all 4 sides look the same?), create the g-code for that single side, run the g-code 4 times to create 4 of the same parts.
    Then take each of the 4 parts, cut a miter on each end, assemble all 4 sides (imagine a box with no top or bottom), then cut a 5th part on the table saw to place inside as the core of the box, take a finish air nailer attach the 4 parts that were cut on the cnc to the core (block of wood).
    That way you could approach all 4 sides of the part, without the need of a 4th axis (on the cnc).
    Free DXF - vectorink.com
  11. #31
    Apr 2006
    3498
    Thank You Switcher for explaination and ideas...hmmm... seems workable but i will think of this method in detail... Your idea inspired me...i will check the CUT3D slice function implementing your technique...
    You are a genious guy Switcher
  12. #32
    Apr 2006
    3498
    Your technique is very good but i am finding trouble for this part, especially in the area as shown in figure
  13. #33
    Then make 2 or 3 slices on each side, glue them together and then miter them.
  14. #34
    Apr 2005
    3634
    Maybe something like this.
  15. #35
    Apr 2006
    3498
    hmmm....still thinking
  16. #36
    Apr 2006
    3498
    something wrong with firefox....it submit twice the post
  17. #37
    Apr 2006
    3498
    A little wish list:
    1- In addition to the software slices feature, If slices can be made bythe user itself(i.e. by defining the cutting planes with help of mouse in different orientation) ...may be a good edition to the software...
    2- If after slicing, each slice behave as an editable model like original one (i.e. can be further sliced into CUT3D), this will give a much detail to the final product.
    By the way the more i think...the more i amazed by CUT3D...it provide much more functionality as compare to its price
  18. #38
    Apr 2006
    3498
    Me leaving to another city...so will meet you next wednesday
  19. #39
    Apr 2006
    3498
    I need a postprocessor so that all my arc convert into I,J ... Currently i am using Flexicam postprocessor on my machine... I hear that I,J make the Gcode shorter hense efficient... If somebody help in this regard...
    NOTE: My controller is based on SLA7062 and it does support I,J command(G02, G03)
  20. #40
    Aug 2005
    597
    Hi Khalid,
    Circular arc - I J - output is typically only available for 2D profile & pocket machining toolpaths and not for the 3D toolpaths saved from Cut3D. Many of the standard GCode postp's in VCarve Pro that include - Arc - in the name will save G2 & G3 - IJ - circular arc moves and these should work for you.
    If you can't get the output to work send a sample toolpath file to support at vectric dot com we can take a look at modifying a post for you.
    Tony
Page 2 of 3 123
  1. G.Weiki rotary atachement (not lathe style) machining tollerances are crap!!
    By phylo in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-14-2013, 04:51 PM
  2. Autocad Style Sketching vs Constraint Style
    By Beefy in forum Uncategorised CAD Discussion
    Last Post: 08-20-2012, 10:26 PM
  3. Can anyone explain the function of a CMM is to CNC Machining???
    By brianklein in forum Digitizing and Laser Digitizing
    Last Post: 10-07-2008, 01:58 AM
  4. News - Cut3D - Low Cost 3D Model Machining
    By Tony Mac in forum Vectric
    Last Post: 04-26-2008, 09:55 PM
  5. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
