586,123 active members*
3,296 visitors online*
Results 1 to 8 of 8
    Apr 2006
    109
    I and J 3D arcs
    Like some help please. I am trying to make a part that I want to mill a radi in the X and Z plane using I and J. right now all I get when I generate G code is X,Y, and Z. Anyone got any helpful hints?
    Feb 2007
    464
    Quote Originally Posted by mmachining View Post
    You need I and K with X,Z.
    Stefan Vendin
    Apr 2006
    109
    I see so in X,Y I diable the K factor and in X,Z or Y,Z I enable is that right?
    Feb 2007
    464
    You don't disable or enable anything.Ok,sorta.
    Just use the right plane.
    XY=G17 Plane IJ
    XZ=G18 Plane IK
    YZ=G19 Plane JK
    With G18 you work in (Enable) the XZ plane.
    Stefan Vendin
    Feb 2007
    464
    This program produce a little bowl.
    Download and install CNCsimulator an try it.
    http://www.cncsimulator.com/
    Code:
    G40  G80 G49 G18 G21
    G0  G90 G54 X0 Y0 T4 S2000 M3
    G43  Z100 H4 M8
    G1  X0 Y14.8 F500
    Z-0.1  F150
    G2  X0 Y14.8 I0 J-14.8
    G0  Z2
    G1  X-14.8 Y0 F150
    Z-0.1
    G3  X14.8 Y0 I14.8 K0
    G0  Z2
    G1  X-14.77 Y0.92 F150
    Z-0.1
    G3  X14.77 Y0.92 I14.77 K0
    G0  Z2
    G1  X-14.685 Y1.84 F150
    Z-0.1
    G3  X14.685 Y1.84 I14.685 K0
    G0  Z2
    G1  X-14.54 Y2.76 F150
    Z-0.1
    G3  X14.54 Y2.76 I14.54 K0
    G0  Z2
    G1  X-14.335 Y3.68 F150
    Z-0.1
    G3  X14.335 Y3.68 I14.335 K0
    G0  Z2
    G1  X-14.065 Y4.6 F150
    Z-0.1
    G3  X14.065 Y4.6 I14.065 K0
    G0  Z2
    G1  X-13.73 Y5.52 F150
    Z-0.1
    G3  X13.73 Y5.52 I13.73 K0
    G0  Z2
    G1  X-13.325 Y6.44 F150
    Z-0.1
    G3  X13.325 Y6.44 I13.325 K0
    G0  Z2
    G1  X-12.84 Y7.36 F150
    Z-0.1
    G3  X12.84 Y7.36 I12.84 K0
    G0  Z2
    G1  X-12.265 Y8.28 F150
    Z-0.1
    G3  X12.265 Y8.28 I12.265 K0
    G0  Z2
    G1  X-11.59 Y9.2 F150
    Z-0.1
    G3  X11.59 Y9.2 I11.59 K0
    G0  Z2
    G1  X-10.795 Y10.12 F150
    Z-0.1
    G3  X10.795 Y10.12 I10.795 K0
    G0  Z2
    G1  X-9.855 Y11.04 F150
    Z-0.1
    G3  X9.855 Y11.04 I9.855 K0
    G0  Z2
    G1  X-8.715 Y11.96 F150
    Z-0.1
    G3  X8.715 Y11.96 I8.715 K0
    G0  Z2
    G1  X-7.29 Y12.88 F150
    Z-0.1
    G3  X7.29 Y12.88 I7.29 K0
    G0  Z2
    G1  X-5.345 Y13.8 F150
    Z-0.1
    G3  X5.345 Y13.8 I5.345 K0
    G0  Z2
    G1  X-1.535 Y14.72 F150
    Z-0.1
    G3  X1.535 Y14.72 I1.535 K0
    G0  Z2
    G1  X-14.8 Y0 F150
    Z-0.1
    G0  Z2
    G1  X-14.77 Y-0.92 F150
    Z-0.1
    G3  X14.77 Y-0.92 I14.77 K0
    G0  Z2
    G1  X-14.685 Y-1.84 F150
    Z-0.1
    G3  X14.685 Y-1.84 I14.685 K0
    G0  Z2
    G1  X-14.54 Y-2.76 F150
    Z-0.1
    G3  X14.54 Y-2.76 I14.54 K0
    G0  Z2
    G1  X-14.335 Y-3.68 F150
    Z-0.1
    G3  X14.335 Y-3.68 I14.335 K0
    G0  Z2
    G1  X-14.065 Y-4.6 F150
    Z-0.1
    G3  X14.065 Y-4.6 I14.065 K0
    G0  Z2
    G1  X-13.73 Y-5.52 F150
    Z-0.1
    G3  X13.73 Y-5.52 I13.73 K0
    G0  Z2
    G1  X-13.325 Y-6.44 F150
    Z-0.1
    G3  X13.325 Y-6.44 I13.325 K0
    G0  Z2
    G1  X-12.84 Y-7.36 F150
    Z-0.1
    G3  X12.84 Y-7.36 I12.84 K0
    G0  Z2
    G1  X-12.265 Y-8.28 F150
    Z-0.1
    G3  X12.265 Y-8.28 I12.265 K0
    G0  Z2
    G1  X-11.59 Y-9.2 F150
    Z-0.1
    G3  X11.59 Y-9.2 I11.59 K0
    G0  Z2
    G1  X-10.795 Y-10.12 F150
    Z-0.1
    G3  X10.795 Y-10.12 I10.795 K0
    G0  Z2
    G1  X-9.855 Y-11.04 F150
    Z-0.1
    G3  X9.855 Y-11.04 I9.855 K0
    G0  Z2
    G1  X-8.715 Y-11.96 F150
    Z-0.1
    G3  X8.715 Y-11.96 I8.715 K0
    G0  Z2
    G1  X-7.29 Y-12.88 F150
    Z-0.1
    G3  X7.29 Y-12.88 I7.29 K0
    G0  Z2
    G1  X-5.345 Y-13.8 F150
    Z-0.1
    G3  X5.345 Y-13.8 I5.345 K0
    G0  Z2
    G1  X-1.535 Y-14.72 F150
    Z-0.1
    G3  X1.535 Y-14.72 I1.535 K0
    G0  G40 Z50
    X0  Y0 M5 M9
    M30
    Stefan Vendin
    Apr 2006
    109
    Stefan, Thanks for the link. I cant seem to get it to work in inches. If I PM you the code I have would you mind running it for me? When I run it in Bob-cad it is not smooth in the simulation. but it looks good when you just look at the toolpaths.
    Feb 2007
    464
    Go ahead and PM me.
    If you want to change the program to inch,just click on "Settings" and login.Password is -login.
    When you have done that,click on "Settings" again and then "Simulation settings" and you'll find what you're looking for.
    Stefan Vendin
    Feb 2008
    11
    Quote Originally Posted by Mitsui Seiki View Post
    XY=G17 Plane IJ
    XZ=G18 Plane IK
    YZ=G19 Plane JK
    I also have been trying to cut curves/radi in xz or yz. Where could I change or select the right plane? Do I chose this on the cad or cam side? When I am trying to cut curves in 3d it breaks it down to little lines and jerks the machine when cutting. If you have any ideas let me know please.
  1. 3d arcs?
    By stevespo in forum BobCad-Cam
    Last Post: 09-01-2007, 02:02 AM
  2. Huge Arcs HELP ?????
    By Biggermens in forum Mach Software (ArtSoft software)
    Last Post: 04-26-2007, 02:50 PM
  3. Huge Arcs
    By Biggermens in forum Mach Lathe
    Last Post: 04-23-2007, 04:49 PM
  4. Smoothing 3d arcs?
    Last Post: 04-20-2007, 12:46 PM
  5. Points on arcs
    By gguidi in forum Autodesk
    Last Post: 07-25-2006, 01:49 PM
