586,395 active members*
2,920 visitors online*
Results 1 to 14 of 14
    Jun 2004
    26
    Ball Screw Question
    I was wondering how much accuracy is possible with rolled 5/8" ballscrews? Could they be accurate to .005"?
    Apr 2004
    439
    Apr 2004
    100
    [i]
    p.s might think about making your own "preloaded nuts" with two cheaper normal nuts. [/B]
    Can you show me how to make the preloaded?
    Apr 2004
    439
    Jun 2004
    201
    I got my ball scews from http://www.mcmaster.com/ for $1.09 per inch
    I used their ball nuts $21.04 each to make a loaded ball nut using Dan's method from Camtronics.
    Instead of turning down the ball nuts he added a coupler
    Then simply put it on the end of the ball screw
    Jul 2003
    125
    That requires a bit of magic to internally thread those couplers to match the ballscrew, doesn't it?
    Jun 2004
    26
    How about ballscrews from Roton. Has any one used these before? How do they preform? http://roton.com/web/balls.jsp
    Jun 2004
    201
    No Dan said to use set screws
    My thought is to use a shear pin.
    Mar 2004
    1806
    I am presently seting up a system using the ball screws from Roton. I have received them and they loolk good. The packaging was supurb and the e-mails that I have had with them has given good me a good feeling. they have been very responsive to my questions and the order was made and recieved in good time.
    Right now, I am still making pieces parts for the assembly and will probably start on the actual machining of the lead screw next week/
    Bubba
    Art
    AKA Country Bubba (Older Than Dirt)
    Jan 2004
    353
    How are you going to drill through the ballscrew?
    Jun 2004
    201
    The shear pin is an oval bar that gets inserted into a milled out section
    Jan 2004
    353
    Ahh with ya now!!
    I was thinking a shear pin across the ballscrew and couldn't imagine how to break the surface to drill the hole!
    Jun 2004
    26
    Another Question.
    Is any one familiar with Nook Industries's ball screw bearing supports? They call them EZZE-MOUNTs. If I were to use those on a router, with direct drive, would I need just 1 on the side opposing the motors? If I went with a belt drive, would I need 2, one on each end of the ball screw. Also, which would be better/more practical on a router, Double Angular Contact Bearings or Single Radial Bearings?
    All input is greatly appreciated.
    Have you checked the price of those things? $$$
  1. Ball screw size/pitch?
    By jakk100 in forum DIY CNC Router Table Machines
    Last Post: 01-09-2016, 04:41 PM
  2. Ball Screw Identification
    By BeerFizz in forum Benchtop Machines
    Last Post: 04-07-2005, 04:28 PM
  3. Ball Screw Mounting Question.
    By Willyb in forum Uncategorised MetalWorking Machines
    Last Post: 01-18-2005, 07:02 PM
  4. Mini Mill 5/8 Ball Screw conversion Question
    By rustyolddo in forum Benchtop Machines
    Last Post: 12-12-2004, 07:24 AM
  5. Need help with Ball Screw Choice
    By samualt in forum DIY CNC Router Table Machines
    Last Post: 09-06-2004, 01:02 PM
