This was a big step for me. I really know nothing about machining but it is something that I have wanted to do for many many years now. I guess that I will have the opportunity now.
I will be using this lathe for mainly making thread adapters (for firearms) and an occasional silencer (when approved by the ATF) and cutting, crowning and threading of various rifle and pistol barrels.
This is what I have on my plate right now.
I need to make a thread adapter to go from M13.5X1 RH to M10X1 LH with an ID of 6.5mm. The purpose of this thread adapter is so I can put my current silencer on a smaller caliber pistol. What type of metal should I use for this and the next item?
I need to make a thread adapter to go from M13.5X1 RH to 1/2 X 28 TPI with an ID of 6.5mm. The purpose of this adapter is so I can put my current silencer on a smaller caliber short barreled rifle.
Both the pistol and rifle use a lesser powder charge than what the silencer was originally designed to muffle so they will operate correctly on the new weapons.
I need to make 2 sleeves .250 in thick with an OD of .520 in and a ID of .370 in. This is for my sons bike so that his new 3/8 in wheel axle can be used on the frame for his bike that is cut to take a 14mm axle. What type of metal should I use?
I have other projects pending but these are my first three projects.
I have also enrolled in a college machining course to get me started with machining. As I already posess a BSCE I feel that this is a good start to continue my education.
Now that I have ordered the lathe, I need to know what type of toolings that I need to get to started off with.
Here is what I am thinking so far:
This kit: http://www.harborfreight.com/cpi/cta...temnumber=3448
I already have the digital calipers.
What other start-up items will I need? I am extremely limited on funding right now.
TIA
