586,617 active members*
2,431 visitors online*
Results 1 to 10 of 10
    Sep 2003
    1472
    Question Need A New Connector For Stepper
    These steppers were originally wired as 4 wire Bipolar I changed drivers to a Unipolar Driver so I had to rewire the connectors. This was not very easy and it is a poor connection now. I ground a notch in an old screw driver so I could press the wire down on both sides of the connector but it wasnt a pretty result.
    I need to replace these connectors and am wondering if there is an easier/better wire connector rather than pressing it down into the connector and the sharp edges of the connector cutting through the insulation, there must be a special tool for this.
    If this is the only type connector that will fit this motor could someone let me know the connector No and where I can find them.
    Hager
    Attached Thumbnails Attached Thumbnails 1ANGLE.JPG.jpg   1PLUGGEDIN.JPG.jpg   1SIDE.JPG.jpg   1TOP.JPG.jpg
    You need to buy the two parts separately. I bought some at Digikey a few years ago, but they don't seem to have them in stock now.
    641653-8
    643077-8
    You should be able to get them at www.mouser.com They don't have the first one, but part 3-641653-8 appears to be the same thing. I think there's a tool, but couldn't find any info on it.
    Apr 2005
    1778
    Hager,
    They are AMP MTA .100" 8 pin IDC connectors. You can order them from Mouser. Their part number is 571-6438138, the AMP part number is 642813-8 and my catalog says they cost $0.48 each, or $0.45 each for 10.
    You can also get covers and strain reliefs, but you can probably use your old one.
    Here is a pdf showing the dimensions for the tool. I made one out of a short handled screwdriver.
    Alan
    Attached Files Attached Files
    Sep 2003
    1472
    Quote Originally Posted by acondit View Post
    Hager,
    They are AMP MTA .100" 5 pin IDC connectors. You can order them from Mouser. Their part number is 571-6438135, the AMP part number is 642813-5 and my catalog says they cost $0.37 each, or $0.33 each for 10.
    Alan
    Thanks Alan,
    What's the trick to pushing the wires down into the connector barbs?
    I ground a slot in a screw driver to push on both sides of the barb but it didn't wirk very good.
    Alan, I think those are the wrong parts. I got my part numbers from a Pacific Scientific data sheet. You can see the difference between the parts.
    Correct part.
    http://catalog.tycoelectronics.com/T...&PN=3-641653-8
    Incorrect part.
    http://catalog.tycoelectronics.com/T...=643813-5&I=13
    Apr 2005
    1778
    Correct part.
    Incorrect part.
    Ger,
    I did have an incorrect part number, I listed the 5 pin part instead of the 8 pin part.
    It may not be what pacific scientific lists in their data sheet but when I bought mine on eBay for more than twice the price, that is what I received and that is what I am using. So they do work.
    Apr 2005
    1778
    Hager,
    I edited my original post to add a pdf that shows the tool dimensions.
    Alan
    Sep 2003
    1472
    Smile
    Hager,
    Alan
    The tool print is a real help. Now I know what to shoot for.
    Thnaks
    Hager
    Jan 2006
    738
    IDC connector tool
    I have a tool specifically for putting wires in those connectors (the original ones) you have. It's a pistol grip design tool that you insert the connector into then insert the wire into a little slot, pull the trigger and it inserts the wire into the connector and then indexes the connector to the next position.
    The bit in the tool that inserts the wire is shaped like this.
    Steve
    Sep 2003
    1472
    Smile
    Quote Originally Posted by vger View Post
    Steve
    Thanks Steve,
    Between you and Alan I should be able to make a tool to do the job properly.
    Hager
  1. Stepper connector type?
    By click in forum Stepper Motors / Drives
    Last Post: 10-25-2006, 03:28 AM
  2. Need help on mill and Stepper connector
    By RedLabel in forum DIY CNC Router Table Machines
    Last Post: 07-27-2006, 04:57 PM
  3. Need connector
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 03-17-2005, 07:26 PM
  4. 25 pin connector
    By polyhedron12 in forum CNC Machine Related Electronics
    Last Post: 02-23-2005, 11:40 PM
  5. Help find terminal connector type for this stepper
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 10-09-2004, 07:34 PM
