586,533 active members*
3,000 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper Motor doesn't spin but makes noise
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Jan 2010
    2141
    Re: Stepper Motor doesn't spin but makes noise
    No, I have no experience with the Marlin firmware.
    Do you have access to an oscilloscope (or to a friend who has one)? It would let you at least determine whether the firmware is actually sending step signals to the driver (and if so, what the timing of the step signal looks like).
  2. #22
    Sep 2014
    20
    This seems like a common theme. I am also having the same problem. I am using the USB smooth Stepper with the C25 board and KL 8070D driver. I have home switches working, Estop working but motors skip steps. When I press the up and down key on the keyboard to move the Y axis the DRO moves approximately .750 before the motor moves. It sounds like it is running but does not turn the shaft until approximately .750 of DRO movement. I have tried steps from 400 to 2000, I have tried velocity from 20 to 400 and acceleration from 1 to 50. Not sure what the next step is and any help would be appreciated.
  3. #23
    Sep 2014
    20
    Not much experience with the KL8070D. I have the steps set to default on the driver. Had it on 2000 but does not make a difference.
  4. #24
    May 2016
    15
    how does one increase the voltage?
Page 2 of 2 12
  1. Help - Motor bumps but doesn't spin
    By etan925 in forum Stepper Motors / Drives
    Last Post: 06-17-2013, 06:49 PM
  2. Stepper motor noise?
    By Drools in forum CNC Machine Related Electronics
    Last Post: 02-16-2013, 01:34 PM
  3. Stepper motor noise
    By speedydumpster in forum Benchtop Machines
    Last Post: 09-02-2010, 11:55 PM
  4. What company makes great but cheap stepper motor?
    By aaronwelder in forum Stepper Motors / Drives
    Last Post: 01-25-2009, 12:53 AM
  5. Stepper motor noise
    By dmparrott in forum CNC Machine Related Electronics
    Last Post: 10-03-2007, 04:35 PM
