Here ya go Neil!
After modifying my spin jig so it would bolt on to my 6x6 sine plate, I made up a stack of jo-blocks and started grinding on an old 1/2" shank end mill!
Now that I have the forming punch. I need to make the guide block and some soft 303-SS blanks!
Soon them cubes will be spinning
Widgit
Just another enhancement.
Before poking the tool into the piece of mild steel, drill a 1 mm hole in far enough so that when you form the socket, it has a hole at the apex.
This should stop any dirt damaging the corner of your cube.
A good day to tinker on my pet project!
I took a piece of tool steel around 1.5" dia, and drilled a 7/8" dia cross hole. Then I drilled and bored a .5005" dia hole for the punch, using my lathe to make sure everything was concentric.
Then I drilled a .1877" dia hole through the remaining length, for the part to slide into. Then I sharpened a flat bottom on an old end mill, and put a nice spot-face around the .1877 hole.
Next, I turned up a quick sample piece from 303-SS, and tried pressing the punch into it with my 6" Kurt Vise. The result was a perfect diamond shape, exactly like that of the cubes corners!
Now I did not drill the 1mm hole in the test piece, but I plan to do that on the final parts! Now it's time to get some small .1875" ID bearings, so I can make up a nice spring loaded frame to hole the cube while it spins!
Widgit
From 5/32 OD upto about 1/2", with or without flanges.
I could put a couple in the mail 4 u.
What size do you want.
My email is in PM. Thanks for using my idea! Nice job.
After making the last post, I placed an order on eBay for ten 3/16 ID x 5/16 OD x 1/8 Shielded bearings for $19.95
Then I fell asleep in my easy chair! When I woke up, I saw your post!
Thanks anyway Neil!
Widgit
Here's a three-step cube I finished today for a final in "Applied Machining" (second semester trade school class.) Pretty fast and loose. Each side had to be done using a different process (boring on a mill, boring on a lathe, milling on a mill/rotary table combo, g-code/Hurco, Esprit/Hurco, and Ultramax Converstional/Hurco.) Fun project. Now that I've seen one, I think I'm going to make one with 6+steps and the rights proportions.
May have to make a stand for it...wonder where I can get plans for that?
:idea:
-Jbot
I dont know how to say this and other way...but WOW!!! I just spent the last hour or so reading every post and looking at every picture, and all I can say is that I am inspired by this entire thread to go out and make one of these cubes. I have only been maching for about 6 months, and I know it will take some time, but those cubes are so damn neat, heh. Anyways, just wanted to say awesome job, and thanks for the amazing imagery and reading material.
Beautiful work, check out his man, it will give you even more ideas he was an incredible turner John Jacob Holtzapffel's
Very cool. any update on the project?
One site every one should see is Robert Bosco site
http://pagesperso-orange.fr/robert.bosco/modeleen.htm
Marcel Beaudry
For some time now I have had an idea for turning all the little scraps of plastic in my shop into something useful!
So I sat down in front of my mill and here is what I came up with!
First I made up around 40 pieces of assorted plastics into .7500" x .7500" cubes, then I used a 5C collet with a square hole in my little indexing fixture. Next I drilled six little holes in each cube, one per side. Then I went to the next size, and the next size, etc.
Now I have a handful of really tiny and proportionate Turner's cubes made out of cast acrylic, white Delrin, black Delrin and some white nylon!
It's amazing what you can do when the lathe is down for repairs!
Widgit
www.widgitmaster.com
It's not what you take away, it's what you are left with that counts!
this is sweet!
i was reading this thread say a month back, weird how its alive again
i didn't know they made square collets... if im looking at it correctly
You guy's have way to much time on your hands!!
NOW GET BACK TO WORK ON YOUR HONEY DO LIST
Enough already!(wrong)
I have a question about the diameters of the circles and depths of each step. How did you figure out the dimensions so that the hole on the neighbor side wouldnt break threw the wall and such. I want to try to make one. If I make one, im freakin framing it and putting it on the wall!
Also, could I just make a fixture that locked into the normal lathe jaws? Say a 6" or 7" piece of stock, face/turn/face and make your same type of clamp system onto that?
I cheated and used a CNC mill to mill the holes out, but the maths is the same- I used.
Bore diameter= 85% of cube face length.
Depth of bore= 15% of cube face length.
Cube 2 face length= Cube 1 face length-(Depth X 2)
This was in acrylic.
I then dyed it black.
Admittedley, it's not a large cube... so when I get some time I'll have a go at this lump of ally
I love deadlines- I like the whooshing sound they make as they fly by.
