ok, no problem
Datei OK F 117
ok, no problem
Datei OK F 117
Hello gentlemen,
Here are tested following file.
Sincerely,
Tomino
Attached is the cleaned version of the Forklift truck.
I am having a cochon de lait this weekend and was hoping one of you would have a dxf file for the 3d pig on page 77. Any help would be great. Thanks
Heres the bulldozer. I am looking for a Kiwi(bird not the fruit) and a Moa. Anyone have any vehicles JPegs, PDF or DXF?
sorry again, i can´t find the concord and the jumbo jet.
i've a lot os dxf files , i can put them here.
just tell me the names.
you sure do get a invite, that's if you're any where near Baton Rouge , La. Thanks a lot, that's just what I needed.
Hi , nice work . I opened zip file im AUTO-CAD and iI notice that on your drawing all lines is not rounded . it consist a lot of straight lines conected in round shape . Do that loke the same after I cut that on CNC router . What can I do to improve that ?
Thanks for your help .
Pictures Puzzles i have done
I opened the bulldozer file and couldn't see the problem you mentioned. I do know that on the Forklift some of the curves are segmented(especailly the bumpers). This is a leftover from the original uncleaned version. If you want to smooth it type PEDIT - Select a segment to join as one - Press J(for join option) - higligh the segments to be joined - - Then press S(for convert to curve)
I draw my designs in ACAD and export them to VCARVE Pro to add reliefs and to make mirror and mutliple copies of parts.
If you would like to post the problem. I will have a look at it.
PS i would also like a copy of the instructions for Woodcraft Spifire Puzzle.
Hi all good and bad
I wonder if some one can help me i'm looking for a dxf of all 52 playing cards.
If some one can help me it will be much help thanks
hello, can someone help me build one of the cranes?
grateful
celia
Metal_shaper,
Next time please ask for something a bit more challenging.
The Dxf may need subtle adjustment, hope this works for your project.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Thanks Jeff..Metal_shaper,
Jeff...
next time i will try a littel harder
Hi guys, I'm new to this forum, but I was curious whether anyone has a DFX file
from the enclosed pictures! Thanks
http://goo.gl/nhKQn
dsaxman if u search in this topic u will find the projects i post Both
