586,108 active members*
3,256 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > Replacing controller on Sherline/Light Machine
    Jun 2007
    4
    I acquired a Light Machine with no controller, just the stepper motors on a Sherline lathe. It is nice with the splashguards, pan, etc.
    I have been using it to make pens, but now I am thinking to get a new controller and restore it back to a CNC lathe.
    What would be the most practical and cost effective way to do this? Do you know any good controllers that would be easy to install on this machine?
    Jul 2005
    31
    Hello Jayhawk,
    Being a Willie the Wildcat type, the jayhawklawrence jumped right out at me.
    I don't know your cost and function requirements, but you might take a look at Bob Campbell's Mach3 Enclosure. http://campbelldesigns.net/enclosure.php You can wire it yourself or buy it turnkey with two, three, four, etc axis capability.
    The components are proabably overkill on a Sherline, but if you trade up to a larger machine, you can keep the control. I bought one of Bob's Mach3 enclosures, factory wired, and I have good luck with it on a Taig mill running NEMA 23 size steppers and Mach3 control software.
    Regards,
    Chuck
    Feb 2008
    11
    IM Service supplied my control 4 my Sherline mill about $800 -$1000 mines a few years old. pretty simple to hook up to my mill not sure about a lathe but I don't see why it should be any differant. DeskCnc software seams to have all the bells and whistles I need. Just add a good drawing software package.
    Jan 2007
    117
    Light Machines Lathe
    I picked up the same lathe you have a few months ago used.
    The first thing you should know is that the Sherline stuff is junk when it comes to CNC integrity. The message boards are full of people who are disappointed with the amount of backlash. Sherline's solution is a goofy lever device that costs $35/axis. I fabricated Nylon nuts which were longer than the OEM brass ones and have reduced the backlash to zero.
    For a controller I would recommend getting 2 Gecko 201's or 203V's along with a break out board and a 50V power supply. You will also need a parallel port cable. The whole thing can be mounted on the underside of the chip pan.
    I have the motor wiring color code written down some place if you want it.
    My lathe is currently disassembled for painting - I find the puke brown color offensive.
  1. Spectra light and Light machine owners have ?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 07-19-2008, 03:52 AM
  2. light machine oil with teflon?
    By juzwuz in forum DIY CNC Router Table Machines
    Last Post: 01-15-2008, 07:14 AM
  3. Machine Recommendations Please - Light Duty, Prototyping, Light Production in metal
    By SCG11762 in forum Uncategorised MetalWorking Machines
    Last Post: 08-27-2007, 02:08 PM
  4. LED Machine Light
    By KaptainKarst in forum CNC Machine Related Electronics
    Last Post: 02-08-2006, 07:57 PM
  5. Replacing Floppy Drive on Machine Controls
    By ObrienDave in forum DNC Problems and Solutions
    Last Post: 08-01-2005, 02:29 AM
