Hi all,
I have a bit of a work emergency here. We have two K2 routers running Mach 2. I'm trying different programs on each machine but have the same problem.
The tool moves to z . 3125 (the first rapid) and does not make any more z moves but the x and y keeps running. It would seem like the Z inhibit is active, but it is turned off and set to 0.0. Also, the readout for the Z axis does not move below .3125. I can jog the Z manually with no problem and the readout indicates correctly.
any thoughts? Help! We need to get this mold into the vacuum form today and it's a 2.5 hour rout on both machines.
thanks in advance!
