Hi all,
I have a dc brush servo that refuses to work properly.
When I switch the machine on it rotates clockwise (looking from the motor shaft end) then trips with 401 and 410 alarm .
Sometimes it just sits there and then trips with 401 alarm.
It never does the same speed on start up more than once!!
I have a Fanuc 6 control with Siemens 6RB 20 transistor chopper drives.
The machine had a violent overtravell/shunt and thats when my problems started.
Is it possible that the case magnets have become damaged in some way.
I have done the usual checks on the tacho, encoder and windings and they all seem fine.
I've had the stack card and drive card checked and repaired by a specialist.
I swapped the motor to another axis and the fault followed the motor.
I had the motor checked out by a specialist and they say its fine??
If I reverse the tach polarity it runs away like crazy! so the motor will run!
Thanks for ant help in advance
John
