586,690 active members*
3,028 visitors online*
    Jan 2004
    668
    Set Up Definition
    OK, just what is meant by "set up", when it pertains to a Bridgeport mill?. I can run one pretty good although I'm not a trained Machinist. I've run up against this description several time while searching for a job. Please explain the function of, " can you do set up " as well as operate?
    Jun 2006
    629
    "Setup" will be can the forman give you a program, drawing material, tools, and a machine and let you get the machine up and running and prove off the first part.
    I believe that's it in a condensed nutshell.
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Jan 2004
    668
    Thanks Mak, thats just what I was looking for. I can do that.
  1. What's the definition of an end mill?
    By Swiss in forum MetalWork Discussion
    Last Post: 08-01-2007, 04:32 AM
  2. Work Holder Definition
    By MAX711 in forum SprutCAM
    Last Post: 12-14-2006, 12:38 AM
  3. MC V9 Casting Stock Definition
    By CAMCRASH in forum Mastercam
    Last Post: 10-12-2006, 09:52 PM
  4. Tool definition
    By David Da Costa in forum Mini Lathe
    Last Post: 07-04-2006, 04:48 PM
  5. Phase definition for SMC 800 controller
    By Magnar in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-04-2006, 01:17 PM
