586,104 active members*
3,250 visitors online*
Results 1 to 2 of 2
    Jul 2007
    25
    uploading problem on mAZAK m32
    Somebody called me with a problem. The guy has a MAZAK horizontal machining center with a m32 control. He programs his machine in G codes and transfers it in the machine from his laptp using the rs232 cable. Most of the time it works. His problem is the following: he gets an alarm when he tries to upload the program from the data in out screen. He had his board checked and they told him the board was working.Is there someone who ran into that problem before and knows what it could be?
    Mar 2005
    988
    What is the alarm? Also, on his laptop, is he using a 25pin serial or 9pin serial? and whats he using for communication software? If it works most of the time then it might just be a bad connect sometimes. Check the cable, adapter (if any), modem crossover (if any), ..... dirt... etc.
    It's just a part..... cutter still goes round and round....
  1. XModem Problem with Uploading
    By paulpeter in forum Haas Mills
    Last Post: 01-31-2008, 04:07 AM
  2. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
  3. uploading problem
    By stubis in forum Tutorials
    Last Post: 05-10-2006, 06:51 PM
