586,395 active members*
2,734 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Perfrormance in 7075 T-6 aluminum
    Sep 2004
    40
    i've been reading up on the Tormach and it seems like it will fit the bill for learning CNC. Looks like a nice way to have a machine to learn on and have around for some small production work later. My question is how does this mill perform it on 7075 T-6 aluminum? Most of what I will be doing is this. I don't expect to set any speed records but it would be nice to know I won't be taking very small cuts.
    Jun 2006
    2512
    Vertical milling machines are not particularly material specific. If its rigid, tight and smooth enough for one material, and the right spindle speeds are available, then the same applies to all materials, up or down graded according to the machineability of the material of course. So the easiest way to get an idea is look at the videos on the Tormach web site. Whether 4500 rpm is high enough depends on what size cutters you are going to be using, if you are down around 3mm then it might be a little slow.
    In its class the PCNC1100 is as about as good as it gets when it comes to removing material quickly.
    As always just my thoughts and opinions.
    Phil
    Quote Originally Posted by DragnsBane View Post
  1. 7075-T6 to 6061-t6 welding?
    By AMCTony in forum Welding Brazing Soldering Sealing
    Last Post: 02-05-2007, 04:24 AM
  2. Milling 7075
    By warpedmephisto in forum MetalWork Discussion
    Last Post: 03-29-2006, 02:23 PM
  3. Aluminum L
    By pminmo in forum Community Club House
    Last Post: 11-24-2005, 10:01 PM
  4. 7075 Aluminum
    By mtechserv in forum Moldmaking
    Last Post: 03-28-2005, 05:27 AM
  5. how to mill 7075 T6 sheet material
    By gcamlibel in forum Uncategorised MetalWorking Machines
    Last Post: 09-08-2004, 07:06 PM
