I am getting this error in mach3 when I try and do a profile mop.
Radius to end of arc differs from radius to startline
The mop is just profiling the outside of a rectangle that has rounded radius corners.
I had someone from another forum load my .nc file into mach3 and they said they did not get the error.
Could there be a config value in my Mach3 that is not right?
Not sure what to look for?
I attached the dxf file and the nc file.
The nc file is .txt cause .nc files are not allowed.
Cambam is doing the cam work here.
Appreciate if anyone has any info as to what the problem is.
